1 - 2 of 2 Posts
where is the fuel pump relay on an 82 P-type? i get no power to the pump with the key on. but if i run a hot wire to it from the battery i get juice. i'm assuming (hoping) the relay is bad, but i can't find it.
The fuel pump is supplied power from the circuit opening relay, which in turn is supplied power from the EFI main relay no. 1. The fuel pump won't run unless you jumper the fuel pump check connector at the AFM or crank the engine over to open the flap in the AFM.
1 - 2 of 2 Posts
