21 - 40 of 51 Posts
Same problem with my 1984 Supra, but the oil pressure gauge started working again !!!
Has anyone here been able to take their car to the dealer now that we are in 2008 and the get this accomplished ??? Would be interesting to know ......................
Thanks,
Mark in Memphis,Tn
1984 SUPRA
ok, went in a week and a half ago, no problems at all. they checked my vin, the recall was still active. they ordered the part for me, it came in last thursday, i went in this morning, they swapped out the oil pressure sending unit. went all smooth.
they were a bit shocked when i pulled in, but never gave me a hard time at all.
I'd suggest all you guys check your vin by calling toyota corporation.
So is this whole list recalls? Or only some? And if so, how do I find out which are which?
(sorry about digging up an old tread)
Thanks Alan!!
Safety Recalls/Service Campaigns for My Vehicle
Vehicle: 1986 Supra JT2MA67L8G0175861
There are no open Special Service Campaigns or Safety Recalls on your vehicle.
See the below list of TSB Technical service bulletins that I sorted & put together from the alldata listings.
+ some associated websites.
Does anyone have access/subscription to the TSB's themselves?
It would be of great value to source the actual TSB's.
http://www.autosafety.org/toyota-lexus
http://www.technical-service-bulletins.com/
http://www.alldatadiy.com/recalls/
Mod YR TSB Number Issue Date TSB Title
1984 32884 FEB 84 ***Paint - Cross Reference Paint Codes
1986-1985 39685 SEP 85 ***A/C - 'O' Ring Inspection and Fitting Torque
1985 55385 MAY 85 ***Seats - Supplier For Leather Seat Fabric Repair
1986-1985 68585 AUG 85 ***A/C - 'O' Ring Kit
1983 115484 MAY 84 ***Wipers - Arm & Blade Modified For Better Performance
1986 122886 FEB 86 ***Audio - Vibration behind ETR Combo Unit
1985 153185 MAY 85 ***Tools - Special Service Tools
1983 191782 SEP 82 ***Paint - Codes and Cross References
1985-1982 241285 APR 85 ***Seat Belt - Replacement Guidelines
1983 291782 SEP 82 ***Indentification - Key Number Location
1986-1985 313185 JAN 85 ***Policy - Digital Clock Claim Submission Procedures
1983 411582 NOV 82 ***Vehicle - Specifications
1985 492184 SEP 84 ***Paint - Cross Referenece Codes
1985 622285 FEB 85 ***A/T - New Oil Tube To Extention Housing
1986 632186 MAR 86 ***Tools - Essential Special Service Tools
1984 632384 MAR 84 ***Drivetrain - Propeller Shaft New Bolt, Nut & Torque
1986-1985 812285 DEC 85 ***Antitheft - Intrusion Monitoring System Description
1985 832685 MAR 85 ***Warranty - Vehicles Originating Outside the USA
1986 1050286 MAY 86 ***Paint - Code Cross Reference
1982 1121082 DEC 82 ***Seat Belts - Use of Toyota Child Restraint Locking
1983 1982 1122482 DEC 82 ***Vehicle - Vibration Diagnosis
1986 1212486 JAN 86 ***Engine - Camshaft Lubrication Improved
1986 1232886 MAR 86 ***A/C - Evaporator Odor
1985 1252185 MAY 85 ***Policy - Warranty Reimbursement on Parts
1985 1352185 MAY 85 ***Brakes - Akebono Remanufactured Calipers
1982 1391082 SEP 82 ***Suspension - Rear Member Cushion Modified
1986 1410485 OCT 85 ***Vehicle - Specifications
1986 1411786 JAN 86 ***Exterior Trim - Front License Plate Installation
1984 1983 1561584 JUN 84 ***Accessories - Electric Antenna Diagnosis/Assembly
1984 1641384 APR 84 ***A/T - ATF, Clutch & Other Changes
1983 1662284 JUN 84 ***Horn - Drain Added
1984 1842784 APR 84 ***A/T & M/T - Transmission Numbers Location/Description
1984 1893083 SEP 83 ***Vehicle - Specifications
1985-1984 1983084 AUG 84 ***Wipers - Motor Gear Replacement
1986 1991285 SEP 85 ***Warranty - Flat Rate Manual
1986 2052386 MAY 86 ***Differential - Production Changes
1986-1985 2101585 OCT 85 ***Policy - Customer Reimbursement Claims
1986-1983 2111786 JAN 86 ***Vehicle - Specification(s)
1985-1983 2112184 NOV 84 ***Driveshaft - (Two-Piece) Replacement Parts & Flow Chart
1985-1983 2122484 FEB 84 ***Engine - Camshaft Housing Gasket Modification
1985-1984 2691484 SEP 84 ***M/T - Gear Tooth Changes Improve 5th Gear
1982 3121082 DEC 82 ***Doors - Striker Adjustment
1985 3610284 OCT 84 ***Vehicle - Specifications
1985 4111284 NOV 84 ***Maintenance - Standardized Schedules
1982 4382082 AUG 82 ***Engine - Valve Compression Spring Modification
1986 7053086 MAY 86 ***Tools - Special Service Tools
1986 10111285 NOV 85 ***Doors - Carpet Repair on Panel
1986-1984 17050286 MAY 86 ***Engine - Rod & Main Bearing Selection
1986 19071886 JUL 86 ***Steering - Brushing/Scraping Noise From Steering Wheel
1986 20071886 JUL 86 ***Audio - Problem Diagnosis Chart
1986-1985 21060686 JUN 86 ***Instruments - Low Fuel Indicator Defect
1986-1984 21121986 DEC 86 ***Antenna - Replacement of Rod Only
1986 23051686 MAY 86 ***Paint - Mica Refinish Information
1986 25053086 MAY 86 ***Vehicle - Theft Prevention Labels
1986 26062086 JUN 86 ***Interior - Roof Side Inner Garnish Squeaks and Rattles
1985 30112884 NOV 84 ***Engine - Drive Belt Tension
1986 35092686 SEP 86 ***Hardtop - Sport Roof Panel Installation Cautions
1983 1982 60441886 APR 86 ***Campaign - Seat Belt Retraction
1986-1982 AC00296 MAY 96 ***A/C - Compressor Maintenance for Stored Vehicles
1986 AC002-98 APR 98 ***A/C - R-12 Air Conditioner System Retrofit
1986 AC002R-98 JUL 98 ***A/C - R-12 Air Conditioner System Retrofit.
1986-1982 AC00396 NOV 96 ***A/C - Alternative Refrigerants and Retrofits
1986-1982 AC93003 MAR 93 ***A/C - System Service/Inspection/Diagnosis
1986-1982 AC93005 OCT 93 ***A/C - Compressor Oil Application & Quantity
1986-1982 AC94001 MAR 94 ***A/C - Replacement Refrigerants Damage System
1986-1982 AC95001 MAR 95 ***A/C - Refrigerant Leak Detection Service Hints
1986-1982 ACC020 OCT 86 ***Antenna - Cable Continuity Check
1986-1982 ATRASIL8726 AUG 87 ***A/T - 43DE/A43DL Differences
1986-1982 ATRATB028 OCT 90 ***A/T - Engine Vacuum Testing
1986-1982 ATRATB078 NOV 91 ***A/T - How To Use A Pressure Gauge
1985-1982 ATRATB162 APR 93 ***A/T - RWD 4 Speed Rough 40545 Upshift
1985-1982 ATRATB192 NOV 93 ***A/T - A40 Series O/D No Fourth Gear
1985-1982 ATRATB197 DEC 93 ***A/T - A40 Series O/D Won't Cancel Fourth Gear
1986-1984 ATRATB294 JAN 95 ***A/T - Drive Axle and Wheel Lug Nut Torque
1986-1982 ATRATB345 JAN 96 ***A/T - Checkball Wear
1986-1983 ATRATB87409 AUG 87 - Throttle Position Sensor Check
1986-1982 ATRATB8748 AUG 87 ***A/T - Slipping or No-Shift/Metal Sealing Rings
1986-1982 ATRATB8754 SEP 87 ***A/T - Front Bushing Wear
1986-1983 ATRATB8765 NOV 87 ***A/T - A43DE/A140E Shifts From 40547 Under Acceleration
1986-1982 ATRATB8809 FEB 88 - Identification
1984-1982 ATRATB8834 JUL 88 ***A/T - Sprag Rotation
1986-1982 ATRATB8923 AUG 89 - Math Formulas Part I
1986-1983 ATRATB8924 SEP 89 - A140E Testing Solenoids For a Restriction
1986-1982 ATRATB8927 SEP 89 - Twenty Steps To Successful Repairs
1986-1982 ATRATB8930 OCT 89 - Math Part II
1986-1982 ATRATB8934 NOV 89 - Application and Lube Chart
1986-1982 ATRATB898 MAR 89 - Identifying Year & Type On Rear Wheel Drive
1986-1982 ATRATB9001002 JAN 90 ***A/T - A40VB Valve Body Interchange
1986-1982 ATRATB9002006 FEB 90 ***A/T - Choosing the Right ATF
1986-1982 AU93001 SEP 93 ***Cellular - Equipment Installation Precautions
1986-1982 AX004-909 MAR 99 Towing Guide
1986-1982 AX005-909 APR 99 Programing the Remote Control
1986-1982 AX006-909 APR 99 Changes For GBS Glass Breakage System
1986-1983 AX93001 JUN 93 ***Antitheft - Transmitter Battery Replacement
1983 AXLE00283 JUL 83 ***Tires - 225/60-14 Snow Tires Availability
1983 AXLE00483 OCT 83 ***Wheel - Aluminum Disc Clear Coating
1986-1982 BO00196 JAN 96 ***Windows - Wire Type Regulator Assembly Installation
1986-1983 BO010-02 MAY 02 ***Child Restraint - Seat Top Strap Installation
1986-1982 BO01196 DEC 96 ***Interior - Carpet Cleaning Precautions
1986-1982 BO91005 MAR 91 ***Seat Belts - Extender Availability
1986-1982 BO92003 FEB 92 ***Seat Belts - Extender Availability.
1986-1983 BO93006 JUN 93 ***Seat Belts - Extenders Availablity
1986-1985 BO94006 APR 94 ***Seat Belts - Extension Availability.
1983 BOD007 NOV 83 ***Body - Addition of Rear Fender Flare Protector
1986 BODY0009 DEC 87 - Required Urethane Adhesive Sealant
1986-1982 BODY008 FEB 89 - Modified Door Stopper Prevents Rattling
1986-1982 BODY011 JAN 88 ***Seat Belts - Rear 3-Point Seat Belt Kits
1986-1982 BODY017R MAY 90 ***Seat Belts - Extender Availabilty
1986-1982 BODY040 SEP 90 ***Doors - Lock Bezel Removal
1985-1982 BODY042013087 JAN 87 ***Seats - Source For Original Toyota Seat Cover Material
1986-1982 BODY046 DEC 90 ***Interior - Repair Kit For Squeaks & Rattles
1986-1982 BR94002 FEB 94 ***Brakes - Cause and Repair of Vibration and Pulsation
1986-1982 BR94004 JUN 94 ***Brakes - Pad Kits Now Available Without Hardware
1986-1982 BR95003 AUG 95 ***Brakes - Introduction of Shim/Fitting Kits
1983 BRAK00321584 FEB 84 ***Brakes - Master Cylinder Standardization
1986 BRAK005 MAR 88 ***Brakes - Pads Squeak and Groan
1986-1982 BRAK011 NOV 90 ***Brakes - Two Pad Kits Now Available
1986-1982 CRIB122 FEB 03 ***Body - Body Sectioning
1986-1982 CRIB146 SEP 06 ***Body - Paintless Dent Repair Information
1986-1982 CRIB1509 DEC 07 - Corrosion Prevention & Sound Absorption Info.
1986-1982 CRIB155 AUG 07 ***Body/Frame - Sectioning Information
1986-1982 CRIB156 AUG 07 ***Electrical - SRS And HV Wiring Repairs
1986-1982 CRIB158 OCT 07 ***Body - Panel Adhesive Information
1986-1982 CRIB161 JAN 08 ***Body - Collision Damage Repair Precautions
1986-1982 CRIB163 FEB 08 ***Body - Sealing Hem-Flanges & Body Seams
1986-1982 CRIB164 SEP 08 ***Vehicle - VIN Plate/Certification Label Replacement
1986-1982 CRIB165 MAR 09 - Acid Rain Paint Damage Prevention/Repair
1986-1982 CRIB167 JUL 08 ***Body/Interior - Trim Removal & Installation
1986-1982 CRIB170 OCT 08 ***Body - Plastic Bumper Refinishing
1986-1982 CRIB172 MAR 09 - Bumper Component Repair
1986-1982 CRIB173 APR 09 - Refinishing Information
1986-1982 CRIB175 DEC 09 - HSS/UHSS Cabin Reinforcement Repair/Replacement
1986-1982 CRIB176 DEC 09 - Approved Collision Repair Methods
1986-1982 CRIB180 DEC 10 ***Vehicle - Usage Of Non-OE Parts
1986-1982 DRIV003 FEB 88 ***Differential - Cover Gasket Changed
1986-1982 DRLN003 FEB 88 ***Differential - Cover Gasket Modified
1986-1982 EG003-03 FEB 03 ***Exhaust System - Sulfur Smell
1986-1982 EG014-05 MAR 05 ***Cooling System - Radiator Cap Inspection Procedure
1986-1982 EL002-98 APR 98 ***Interior - Cigarette Lighter Service
1986-1982 EL95004 NOV 95 ***Instruments - Wiper Motor Circuit Breaker Inspection
1982 ELE001 MAR 83 ***A/C - Noise From Heater Blower Motor
1983 ELE006 JUL 83 ***Wiring - R&R Fusible Link Wire/Fusible Link Availability
1983 ELE007 AUG 83 ***Lights - Headlamp Retractor & Cleaner Modifications
1984 ELE010 NOV 83 ***Charging System - Improved Cooling For IC Regulator
1983 EMIS00183 FEB 83 ***Emission - Sulphur Odor From Exhaust
1986-1982 EN91007 JUN 91 ***Ignition - Revised Signal Generator Resistance Specs
1983 ENG00483 FEB 83 ***Fuel - New Start Time Injector Improves Starting
1983 ENG00983 APR 83 ***Engine - Oil Filter Installation Precautions
1986 ENG010 SEP 89 - Hard Starting/Long Cranking Time
1986-1982 HEAT007 SEP 89 - Updated Evacuation Procedures
1986-1982 PA003R-02 FEB 05 ***Paint - Refinishing Bumper Cover
1986-1982 PA95001 SEP 95 ***Paint - Repairs On Polyurethane Bumper
1986-1982 PG001R-06 NOV 06 ***Electrical - Battery Maintenance and Testing
1986-1982 PG004-97 JUL 97 ***Body - Replacement Certification Labels
1986-1982 PG005-97 JUL 97 ***Body - Replacement VIN Plates
1986-1982 PG007-07 NOV 07 ***Vehicle - Replacement VIN Plate Information
1986-1982 PG93002 APR 93 ***ID - Replacement VIN Plates and Certification Labels
1986-1984 PG94002 JUN 94 ***Emissions - Control Labels Ordering Form
1986-1982 PG95005 JUN 95 ***Emissions - Control Label Order Form
1986-1982 PG95006 JUL 95 ***Bolts - Standard Torque Specifications
1986 PGI0109 NOV 85 - Schedule
1986-1982 PGI015 JUN 89 - VIN Plates and Certification Labels Replacement
1986-1982 PI91002 JAN 91 ***ID - VIN Plates and Certification Labels Replacing
1986-1982 PI91006 SEP 91 ***Cooling System - Using Recycled Coolants
1986-1982 PI91008 NOV 91 ***Emissions - California Emissions Information Labels
1986-1982 PIG035 NOV 90 ***Towing - Guide
1986-1982 SB0258-08 SEP 08 ***Restraints - Seat Belt Tongue Plate Stopper Replacement
1984 SPECS9909 OCT 83 - Specifications/Model Identification
1986-1982 SS002-97 SEP 97 ***Brakes - Booster Push Rod Gauge
1986-1982 SS003-98 DEC 98 ***Accessories - Rivet Nut Tool
1986-1982 SS93001 MAR 93 ***Suspension - Coil Spring Compressor Warnings
1986-1982 SS94002 AUG 94 ***Wiring - New Harness Repair Kit Available
1986-1983 SS94003 AUG 94 ***Tools - Toyota Checker Applications
1986-1982 SS95-003 OCT 95 ***Engine - Tripod Support Bar
1983 SSC312 DEC 84 ***Recall - I.C. Voltage Regulator Replacement
1986-1982 ST002-98 MAY 98 ***Steering - Gearbox Removal Precautions
1986-1982 SU00296 MAR 96 ***Wheels - Balance Adapter Kit
1986-1982 SU00296R SEP 96 ***Wheels - Balance Adapter Kit Update
1986 SU95004 JUL 95 ***Suspension - Shock Absorber Cartridge Replacement
1983 SUS00183 FEB 83 ***P/S - Control Valve Oil Seal More Effective
1983 SUS00283 DEC 83 ***Steering - Slight Flutter Reduced By Suspension Change
1986-1982 SUSP002 JAN 89 - Front/Rear Shock Absorber Rattle
1986-1982 TC002-909 APR 99 Revised Drive Shaft Grease
1986-1982 TC003-909 MAY 99 Fluid Interchangeability
1986-1982 TC003-98 JUN 98 ***A/T - Fluid Type T-IV Replaces Type T-II
1986-1984 TC00496 DEC 96 ***A/T - Serial Numbers/Identification
1986-1982 TC95008 AUG 95 ***M/T - Replacement Parts, Set Required
1983 TRANS004 MAR 83 ***M/T - Clutch Disc Outside Diameter Increased
1986 TRANS005 JUN 89 - Check Ball Added For Smoother Shift R to
1986-1982 TRANS006 JUN 89 - Transmission Oil Cooler Flushing
1986-1982 TRANS007 JUL 89 - Valve Body Rubber Check Balls Modified
1986-1982 TRANS007 JUL 85 ***A/T - Engagement Time Reduced
1986-1983 TRANS008 AUG 85 ***A/T - Torque Converter Lock-Up Clutch Not Releasing
1986-1983 TRANS011 DEC 83 ***M/T - Pre-Balk System Inhibits Gear Grinding in Reverse
1984 TRANS013 DEC 83 ***A/T - Fluid Standardization
1986 TRANS016 SEP 89 - Torque Converter Mounting Bolt Procedure
1982 TRANS030 FEB 83 ***A/T - Modifications For Improved Performance
1986-1982 TRANS036 SEP 90 ***A/T - Torque Converter Mounting Bolt Caution
1986-1985 TRANS038 SEP 90 ***A/T - Valve Body Modifications
1986-1982 WARR88209 OCT 88 - Authorized Removal of Warranty Parts Form
1986-1982 WARR8823 SEP 88 ***Warranty - A/C Compressor Diagnosis Check Sheet
1986-1984 WARR8903 DEC 88 ***Warraty - 1984-1988 Flat Rate Manuals Available
1986-1982 WARR8904 DEC 88 ***Warranty - Battery Replacement Proration Chart
1986-1982 WARR8905 DEC 88 ***Warranty - Operation Codes for Air Conditioner Claims
1986-1982 WARR8916 APR 89 - Genuine Toyota Motor Oil Available
1986-1982 WARR9004 OCT 89 - Radio Debits
1986-1982 WARR9005 OCT 89 - History Available Over TDN System
1986-1982 WARR9012 DEC 89 - Remanufactured Compressor Serial Numbers
1986-1982 WARR9041 JUL 90 ***Index For Dealer Support Materials
1986-1983 WARR9118 JAN 91 ***Warranty - Discontinuation of Radio Questionnaire
I have access to TIS. When I searched for TSB's with it it only shows 25 documents but my search criteria was specific to 1985 Supra. TIS doesn't have much information for older vehicles, it doesn't even have a repair manual for the Supra until 1990.
The only document it had from your list is BO010-02. The year and title of the document is different on TIS but I don't think that should matter. It is in .pdf format, if you want I could send it to you.
BO010-02: 1983-2000: Child Restraint Seat Top Strap Bracket Installation
Don't know why this site won't work. It worked before IIRC. I submitted an inquiry to them.
https://auth2.toyota.com/owners/SSCInfo-index.html
How did you contact them? Is there an e-mail address? I would like to get these 2 sites to work:
http://www.toyota.com/owners/apps/service-publications.do
http://www.toyota.com/owners/apps/owners-manuals.do
You can see the service-publications.do site by going to:
http://web.archive.org/web/20110426194057/http://www.toyota.com/owners/apps/service-publications.do
But the owners-manuals.do isn't archived.
I found this site:
http://www.toyota.com/owners/web/pages/resources/recalls
But the VIN# for my Supra didn't work. My 1995 and newer vehicles VIN# worked though. I'm guessing VIN# older than 1990 will not work.
Below is the interaction I had with Toyota Customer Experience. Essentially they looked up my VIN#'s. Every new year they drop off one old year from C. 15 years ago. This is why the old VIN's are rejected.
Notably the SSC#410 Oil Pressure Sender Gauge issue is still open and apparently doable.
Recently you contacted Toyota. Below is a summary of your contact message and our response.
Thank you for allowing us to be of service to you.
Subject
VIN# error
Discussion Thread
Response (Joanne Hahn) 11/11/2011 01:47 PM
Argoodlv Argoodlv,
We have checked your VIN (Vehicle Identification Number) JT2MA67L5E0107627 and determined that your 1984 Supra is involved in the following SSC which is outstanding:
SSC#: 410
SSC Name: MX/MA Oil Pressure Sender Gauge
Please contact your local Toyota dealership, www.toyota.com/dealers, for completion of any outstanding SSC.
Joanne Hahn
Customer By Email (argoodlv argoodlv) 11/11/2011 12:56 PM
Thanks for the response.
I overlooked one VIN# that was recently confirmed to have an outstanding item.
JT2MA67L5E0107627
Subject
VIN# error
Discussion Thread
Response
(Joanne Hahn) 11/11/2011 10:15 AM
Argoodlv Argoodlv,
We apologize for the delay in our response.
We have checked further your VIN (Vehicle Identification Number) JT2MA67L3F0140336 and determined that your 1985 Supra is involved in the following SSC which is outstanding:
SSC#: 501
SSC Name: Engine Maintenance Label
VIN (Vehicle Identification Number) JT2MA67L3F0159968 and determined that your 1985 Supra is currently not involved in any Special Service Campaigns.
VIN (Vehicle
Identification Number) JT2MX73E3J0155455 and determined that your 1988 Cressida is currently not involved in any Special Service Campaigns.
VIN (Vehicle Identification Number) JT2MA71J2K0124698 and determined that your 1989 Supra is involved in the following SSC which has already been completed:
SSC#: P0I
SSC Name: Air Conditioning Expansion Valve
Dealership: Bill Maxey Toyota
Date: September 7, 1993
As for the VIN JT2MA67L3F0159968, we do not follow NHTSA's Campaign Number and do not
show there is any outstanding campaigns in our system.
A TSB is a communication between Toyota and its dealerships that can serve as an update to Toyota publications, describe parts updates, or relay enhanced or new service procedures. Service procedures may explain diagnostic steps, implementation of recommended updates, or how to perform certain repairs. A TSB is not a recall or a Special Service Campaign. If the cost of a TSB service or repair is eligible for warranty coverage, it will be specified
in the TSB, and requires that the vehicle is within the original warranty parameters and exhibiting the concerns referenced in the TSB. A TSB does not extend the warranty.
Toyota makes all available TSBs accessible to the public by subscribing to our Technical Information System.
Title: Technical Information System (TIS)
URL: http://techinfo.toyota.com
You can also purchase TSBs through the National Highway Traffic and Safety Administration (NHTSA) which is part of the U.S. Department of
Transportation (DOT).
NHTSA - National Highway Traffic Safety Administration
U.S. Department of Transportation
Washington, DC 20590
800-424-9393: DOT automotive safety hotline, toll-free
202-366-0123: DOT automotive safety hotline, direct
Once the warranty has expired, all repairs (including the performance of technical service bulletins) become the vehicle owners responsibility.
Please contact your local Toyota dealership, www.toyota.com/dealers , for completion of any outstanding
SSC.
Your email has been documented at our National Headquarters.
Joanne Hahn
Customer By Email (argoodlv argoodlv) 11/07/2011 02:40 PM
I am looking for recalls and TSBs for my vehicles. And the whole very active Toyota and Supra ownership base is looking as well.
A few megabytes of memory costs so many decimal points less than the cost of even one lost vehicle sale. This makes it a no brainer judgement for an astute customer relations department. I don't believe
information drops off your parts department database in the same way.
This is clearly a legal liability and responsibility issue as well as a likely NHTSA issue. It is also
a nonsensical and contra-indicated customer relations "tactic" to discard product safety, customer useful information before the end of the product's useful life.
Please remind management that you are making quality long lasting vehicles which attracts buyers who are paying for that durability. To not properly support your
product's durability says that you don't wish to fulfill the vendor/customer commitment.
There are some 200+ TSBs for my Supras (of which a certain number are safety issues). Some
were issued 27 years after model year. It makes no sense to hide/drop their information from the consumer after 15 years.
I wish to know what they are.
JT2MA67L3F0140336
JT2MA67L3F0159968
JT2MX73E3J0155455
JT2MA71J2K0124698
NHTSA Campaign Number: 84V108000 is still active for JT2MA67L3F0159968
Subject
VIN# error
Discussion Thread
Response (Joanne Hahn) 11/07/2011 01:33 PM
Dear Argoodlv Argoodlv,
Thank you for taking the time to respond.
Our
system goes far back as 1995 and as we come upon a new year the oldest year falls off our system and will then have very limited information on the older vehicles. Is there anything specific you are seeking?
We look forward to your response.
Joanne Hahn
11:55 AM
The VIN is an 85 Supra. I have seen references by others in our Supra groups that earlier VIN's don't show up. It seems strange that I can find a breakdown
reading analysis of the VIN on other web sites but "Official" Toyota itself doesn't read it as a valid #.
Please keep this incident open and request that your website update its database to at least be equivalent to the Toyota Parts dept capability.
-----Original Message-----
To: argoodlv
Sent: Mon, Nov 7, 2011
11:44 am
Subject: VIN# error [Incident: 111104-000064]
Response (Joanne Hahn) 11/07/2011 11:44 AM
We appreciate the time you have
taken to email us.
The VIN you have provided JT2MA67L3F0140336, is not coming up in our system, it could be possible that this vehicle is not a U.S. specific vehicle.
If we can be of further assistance, please utilize the following link to find a variety of avenues to contact our offices, http://www.toyota.com/help/ .
Sincerely,
Joanne Hahn
iss
Our system goes far back as 1995 and as we come upon a new year the oldest year falls off our system and will then have very limited information on the older vehicles. Is there anything specific you are seeking?
Joanne Hahn
Response (Joanne Hahn) 11/11/2011 10:15 AM
Argoodlv Argoodlv,
SSC#: 501
VIN (Vehicle Identification Number) JT2MX73E3J0155455 and determined that your 1988 Cressida is currently not involved in any Special Service Campaigns.
SSC#: P0I
As for the VIN JT2MA67L3F0159968, we do not follow NHTSA's Campaign Number and do not show there is any outstanding campaigns in our system.
A TSB is a communication between Toyota and its dealerships that can serve as an update to Toyota publications, describe parts updates, or relay enhanced or new service procedures. Service procedures may explain diagnostic steps, implementation of recommended updates, or how to perform certain repairs. A TSB is not a recall or a Special Service Campaign. If the cost of a TSB service or repair is eligible for warranty coverage, it will be specified in the TSB, and requires that the vehicle is within the original warranty parameters and exhibiting the concerns referenced in the TSB. A TSB does not extend the warranty.
You can also purchase TSBs through the National Highway Traffic and Safety Administration (NHTSA) which is part of the U.S. Department of Transportation (DOT).
Once the warranty has expired, all repairs (including the performance of technical service bulletins) become the vehicle owner’s responsibility.
Joanne Hahn
mine reads at about 20 psi at idle and about 40 normal driving. do yall think that 20 at idle could be a faulty sender gauge? i mean obviously. i know alot about cars but what im asking is, is this what happened to any of yalls before replacing the sender gauge? and would it happen to cause a leak right by the alternator? (not sure where the leak would take place, im new to supras)
21 - 40 of 51 Posts
