Gauge lights
Probably the guage light dimmer pot under the cluster, on the left side.
These things are notorious on all cars for getting corroded and making bad contact. Wiggle it back and forth and your problem should be temporarily solved. For more permanent solution, get some contact cleaner from Radio Shack and disassemble the unit and spray the cleaner on the contacts and maybe even clean it out with Q-tips, if you want...
