Do any of you have the problem when u change gears to reverse does it grind before going into reverse, is a big problem or just a minor one, should i fix it right away?
Like others said that's normal but there's a way to quickly stop the spinning input shaft. Just put it in 3rd and barely release the clutch (not all the way out) to where you can feel the clutch drag then you can put it into reverse without any grinding!supra83mkii said:Do any of you have the problem when u change gears to reverse does it grind before going into reverse, is a big problem or just a minor one, should i fix it right away?
