Hey Supra fans!
Well, like the subject suggests, when I'm stopped with the engine running and press the clutch and attempt to move the shifter into first, I sometimes have a hard time getting it in there. Sometimes I need to pump the clutch a few times before it opens up and really push the clutch pedal into that carpet - other times it moves in with ease. Usually when the car warms up it gets better, but now with the weather getting cooler it seems to be more of a problem. If the car is rolling even a little bit it's usually quite easy to get it into first. I also noticed that when stopped on flat ground and put it in first gear while the clutch is in, the car may start to creep forward and then stop as soon as I pull it out of gear. This also seems to go away as the car warms up.
It seems to me as if the hydrolic lines or the master/slave cylinders might be leaking, but I don't see any leaks. Should I try bleeding the line or is it most likely an issue with something inside the tranny itself? I replaced the tranny oil about two months ago and it didn't really change this behavior. Any thoughts? Keep in mind I pretty much know nothing about how transmissions work internally...
- Mike
- Mike
