Hmmm...so YOU'RE the dickhead that I love to slam my brakes for when you're riding my ass in traffic eh? I love it when people ride my butt in the Supra when traffic is too heavy to move at a faster speed. Riding someone's ass just pisses them off, and increases the likelihood of an accident.batmobile said:they do when im on their ass! :twisted:
Birddog said:Bringing up the topic again, does anyone know how to use the rear windshield jets? I've noticed a plactic bladder in the rear trunk area of my MkII that i suppose is where the fluid is pumped out of to the rear jet. But don't know if that's true, and can figure how to opperate the rear jet. Anyone know how to get it working?
SuprAlaska83 said:Maybe the '84 is different than my '83?
lol, this car will always amaze me.SuprAlaska83 said:BTW, if you're wondering how to poor fluid into the washer fluid bag, the access panel doubles as a funnel. And it works too.![]()
wwwwwwwwwwhaaaaaaaaaaaaaaat...?SuprAlaska83 said:BTW, if you're wondering how to poor fluid into the washer fluid bag, the access panel doubles as a funnel. And it works too.![]()
Comon guys... Even I figured that one out....chrisfromda909 said:wwwwwwwwwwhaaaaaaaaaaaaaaat...?
If you simply push the lock in on the inside of the drivers door, it should lock both doors. Same applies to locking or unlocking the drivers side door with the key from the outside. It will lock/unlock both doors when you turn the key. If yours doesn't work this way, it is due to a broken wire on the drivers side door lock solenoid. You need to remove the door panel to get to it and solder it back on.SuprAlaska83 said:Ah hah! I must say that the door lock switch on my '83's center console is a PITA. Thanks.![]()
And this was a new feature in 83, correct?Dean said:If you simply push the lock in on the inside of the drivers door, it should lock both doors. Same applies to locking or unlocking the drivers side door with the key from the outside. It will lock/unlock both doors when you turn the key. If yours doesn't work this way, it is due to a broken wire on the drivers side door lock solenoid. You need to remove the door panel to get to it and solder it back on.
That's how my '83 works.Dean said:If you simply push the lock in on the inside of the drivers door, it should lock both doors. Same applies to locking or unlocking the drivers side door with the key from the outside. It will lock/unlock both doors when you turn the key. If yours doesn't work this way, it is due to a broken wire on the drivers side door lock solenoid. You need to remove the door panel to get to it and solder it back on.
