1 - 5 of 5 Posts
whats the cause of the headlights not going down? ive checked the fuses and the motors and there all good. i think theres a couple realys in there. do any of you know which one could be dead and where is it located.
search, many have had this problem.
i have that problem right now.
i've just been putting them up and down manually for the time being... i have no time to search out the problem.
there's a coupe relays... one is by the worklight under the hood, and another is hidden way behind the dash on the driver side. they both say something about headlight motor control... i dunno.
good luck, let me know if you get it fixed.
My Fix
I had this problem and i replaced relays and fuses and they did not go down. I then found that there is a small green connector that goes to the positive terminal of the battery that works the light motors. One of the wires was loose, so i fitted a new wire and then they worked perfect and have ever since. Give this ago, if not this i can't think of what this could be.
Good luck
:lol:
Barnzi
Yea mine stayed up all the time also. I checked the wires on the pos. side of the battery and the small one was broken. My pos. side has three wires. Starter, Alt. and headlites. I spliced it back in and it works fine now.
1 - 5 of 5 Posts
