NOTE: this is on an MKI.
I'm at my wit's end. I pulled apart my whole dash board to replace my heater core, since it was dumping antifreeze into my vents. I got that taken care of, heater core is replaced, no leakes, only now I have discovered another problem. The temperature slider does not work! I believe this to be an existing problem and was there before I took everything apart, so it is not something that I forgot to hook up. The temp is stuck on full cold no matter what I do to the slider. If it were a cable control, this would be no big deal, but since its a bunch of wires and vacuum lines and solenoids, etc., I figure I'm pretty well screwed as far as getting this thing to work properly ever again. Anyone have any suggestions? I refuse to ask or deal with a shop on this as I'm sure the bill would be way too much. My only thought was to run a cable to the temperature box and then hook a knob to it, sort of like a manual choke controller and use that to control the temp. Any other help?
