1 - 4 of 4 Posts
I have my 85 p type and i got a 7mgte's turbo and a manifold and a inter cooler. what else to i have to do to make this work? like the oil and the coolant? do i have to drill into the block or what ?
Curious in Kirkland
cheers
:drinking:
You need the I/C pipes too. Best way for oil is to use a brass tee on the oil press sensor and send to turbo. Tap into oil pan for turbo oil outlet. I used the TB coolant lines and split them off to the turbo.
Before asking common stuff like this, check out the FAQ. Theres a lot of useful info there. Theres a link there for 5mgte stuff to Aaron Garney's site. Its explained in detail there. Then if you need further explanation we'd be happy to help.
Christian
1 - 4 of 4 Posts
