Funny, I just tried to revieve an old thread in the engine section on this vary topic. I got nuffin. Maybe old threads are ignored or nobody actually had any new info to add. I dunno...
Anyway, what are you planning to use the MegaSquirt for? Personally I am thinking about using it to fuel a 5M turbo 82 and possibly an 84 dirt tracker. I think tunning the cold start enrichment will be a total pain in the A$$ 'cause it has to be started at cold soak conditions. It will take a full winter of screwing around to get it set properly. I don't think that the rest of the tuning would be that big of a deal as long as I get a wide band O2 sensor in the original setup and use the data logger.
Ignition on the 84??? I got no clue. I wanted the same info. I know that the same people who did the MegaSquirt are working on a MegaSpark but I think it's still a ways off. There must be a way to keep the Toyota ecu reading engine sensors like just putting resistors equivilent to injector resistance and grounding them all. Maybe by altering the coolant sensor you could force the ecu into open loop operation and ignore all the sensors? (might hurt performance?) I'm looking into this hard core but might not get around to actually doing it untill spring. I would love to get some input on this from others... but I'll figure it out on my own if I have to. It will just take a bit longer.
