41 - 53 of 53 Posts
Right p/n 81730-19306
Left P/N 81740-19286
There's aftermarket on Amazon or if you want OEM
or
Reactions: gabessupra
WOW!
Looks familiar. Can I ask what setup you used to polish your rims? I tried to polish mine but the compound was not good and I ended up doing it by hand (not a very good job). What was the paint you used?
Discussion Starter #47
Wow is right! Looks like they're twins!
So I spent about 5 hours and worked my fingers to the bone to get them looking pretty good.
The first thing I did was sprayed a diluted acid based cleaner and used a very harsh cone type brush to penetrate the rims. Then used 400grit sand paper on every hole. Then power wash. Then dried them off perfectly, and started using the buffing process with compound. After a ton of buffing with compound I started to use Mother's Mag cleaner with a different buffing wheel. After doing all the rims I power washed them with soap again. Dried them off again and manually applied Mother's chrome polish. Once they looked good I used black laquer touch up paint to do all the black lines.
Easy stuff 😜
Easy stuff 😜
Gabe,
Did you use an Aluminum buffing compound to start with? What kind of paint did you use between the 'spokes'. Its some kind of silver paint?
Discussion Starter #51
or
Aren'the right and left lenses interchangeable?
Gabe, do you have any photos of the interior or under the hood? I'm interested in finding out if our cars were identically equipped from the factory.
41 - 53 of 53 Posts
