1 - 2 of 2 Posts
I have now come across an idle problem. I do believe i fixed the timing because the car starts. Its lower rps are a bit rough but it seems to clean up when you bring the rpms up. However when you let the car sit it slowly idles down and dies. A friend that has an 87 and an 83 suggested vacuum leak but i dont know where those hoses are. I also replaced my plugs and wires. Havent taken it out for a drive to see how it would act because i cant get it to idle for over a min. It is still shaky while the rps are being brought up until your at or above 1700 then it seems to smooth out. Please help i need the car to run well it is my daily driver and i never feel right if its not running.:sadbanana:
Have you made sure the EGR is not open?
Make sure you do not have a leak at the ICS valve hose. It is located left of the TB when standing at the drivers side fender looking at the engine.
1 - 2 of 2 Posts
