1 - 6 of 6 Posts
I was with the crew and i had a chick in the right seat so I had to through it around so I slid it around a corner and now my idle is at 2000 NEED HELP
Throttle plate isn't closing all the way, idle speed control valve is wide open, or you've got a vacuum leak somewhere...
1: Listen for hissing of a vacuum leak.
2: Listen for actuation of the ISCV after shut-down (click-click-click-click)
3: Look for any indication that the throttle plate isn't closing against the screw-stop.
--billyM
Tighten all the screw clamps on the intake connectors between the AFM and TB??
If the PCM offers no hints, the best place to begin looking for problems is with the Idle Air Control Valve/Bypass Air Control. You can try cleaning it and see if that improves your idle speed. A throttle body cleaning is likely to cure the high idle speed as well
That condition is USUALLY caused by a vacuum leak.
Multiple places to look.
Old mechanics looked for vacuum leaks with a propane torch. Attach hose to the end(NO NOZZLE) and tape a LONG screwdriver to most of that hose and go fishing.
When you hear the engine speed up, you found a vacuum leak.
The cooling fan may cause trouble with the wind it causes.
Don't light...btw
Reactions: Beernuts and ddd228
1 - 6 of 6 Posts
