1 - 9 of 9 Posts
I probably have one sitting in my parts stash somewhere.
Can you post a pic with the part numbers visible?
Discussion Starter #3
Can you post of pic with the part numbers visible?
No pic - car not here and nothing of worth in online photos. Sits behind fuse box near battery.
There are 3 part numbers listed on an original ignitor/coil assembly
19070-43071 Coil w/Igniter (08/1983 – 11/1985) 3-pin connector
89620-14361 Igniter (08/1983 – 11/1985) 3-pin connector.
90919-02154 Coil (08/1983 - 11/1985) 3-pin connector
Thanks
I was hoping for a photo to confirm part numbers.
I looked today. Mine were sitting on a shelf in my parts shed but I didn't mark on them which years they each came out of since I figured I'd just match up the part number if/when I was going to use any one of them to replace a bad one.
But what are the numbers listed on your igniter/coil assembly? I can sell you one that matches up with the numbers on yours or I can sell you one that matches up with the numbers listed on 'an original ignitor/coil assembly' which may or may not be the same as yours. I have several available. LMK.
This may or may not help you. Several years ago the igniter on my 1983 Supra died. I spent several weeks trying to find a used one and finally gave up. I bought a used igniter from a 1986 – 1992 Supra, Toyota part 89620-14430. The newer igniter uses different connectors but the unit is the same size and shape as the older one. I had to cut the connectors from my 1983 igniter and splice them on the newer one. No mounting modifications were needed. The car has driven fine ever since.
I have a couple here that I grabbed from my parts barn. Your choice: 89620-14361 or a 89620-14360.
1 - 9 of 9 Posts
