1 - 5 of 5 Posts
hello
i just purchased a 83 supra so i ran to my closest jap import and asked for a 7mgte, it was only 750 cdn.
so here are my questions
i saw the motor and its just motor with turbo and some ic piping cut.. and some of harness, i forgot to ask what year coz i was all excited= (
-so what should i be looking for ?
-what ecu should i get coz they dont have it ?
-how hard is the wiring ? ima pretty good with wiring i have converted a honda from obd 0 to 0bd1
-what other parts do ?
-is there a step by step swap info site?
TIA =)
Discussion Starter · #2 ·
one more ?
i was reading up a bit and howcome you have to use the 5m oil pan and mod the 7m oil pump to fit ?
if i have to run the 5m oil pan ? can i just run the 5m oil pump too? does any one else run the 5m oil pump ??
Hey man...welcome to the club. You'll find all the info you need in the 5/6/7mgte thread.
This topic has been covered a few hundred times so there's more than enough info there. In regards to the oil pan...you have to use the 5m pan cause the 7m one won't fit over the cross-member...give yourself some time and scroll through the threads...you'll find you'll learn a hell of a lot that way.
Ciao
1 - 5 of 5 Posts
