21 - 34 of 34 Posts
For those curious:
Denso Injectors 195500-2020 550CC @ 43.5 PSI 13.5 Ohm
These are what I use on my 7M (with the AEM). They direct fit into a 7M if you shave the locators off with an exacto knife. They are high impedance so if you remove the resistor pack it should work fine on a standard 7M. You can get them off 89-92 S2 RX7 turbos. If you go to the RX7 boards you can get a whole set of 6 for about $150. HTH
whats the info to witch hunter? im thinkin of sendin my pte's in to be tested. they were supposedly rebuilt before i got them but i want to be sure before i push the motor hard after its rebuilt. also want to send those venom 830's in just for shiz and giggles to see how bad they are.
Anyone have directions/ pics suggestions on how to remove the resistor pack.
Cut the plug with wiring off the resistor. Solder all the wires together on the plug and reinstall the plug.
First plug-1 wire = 12V feeder
Second plug -2wires => each wires feeds 3 injectors. split is done in harness.
Guess I have another vendor on my build list. I'm going to send them my 720's and some 440's or 550's for the break-in period/mild tune
According to his calculator, I need to run 87% duty cycle on the 720's for 600chp......and I thought I had too much injector
I used to use witchhunter, then they raised their rates and started hating on the candians.
I now use this guy: http://www.cleaninjectors.com/
His name's Tim, and he runs a tight ship. You get flow, opening time measurement, cleaned, reflowed, and all the little replaceable bits replaced for $11 each. THEN he gives you a subjective review of the flow pattern and set balance (priceless).
I trust him 100% with my stuff and wouldn't use anyone else, and I'm an ex-witchhunter convert.
--billyM
From another forum.. part numbers useful..
Stock 1UZFE Injector:
Code number: 23250-50020
Overall Length: 2.800"
Injector Tip Length: .260"
Injector Inlet Length: .614"
Injector Tip Diameter: .368"
Injector Inlet Diameter: .415"
Injector Opening:2
Injector Connector: Type F
Flow Rate: 251 cc/min
Impedance: high 13.8 ohm
Stock 7MGE Injector:
Code number: 23250-70080 Light Green Tip
Code Number: 23250-70040 Yellow Tip
Overall Length: 2.810"
Injector Tip Diameter: .370"
Injector Inlet Diameter: .416"
Injector Opening:4
Flow Rate: 315 cc/min Light Green
Impedance: High 13.8 ohm
Stock 7MGE Injector (Yellow):
Injector Opening:4
Flow Rate: 295 cc/min Yellow Tip
Impedance: Low
21 - 34 of 34 Posts
