1 - 2 of 2 Posts
IMHO if it did get you to 7psi I would think that they might be above 80% duty cycle. If you use the 210's make sure you start out with stock boost and see what the wideband says. Then increase boost slowly and keep an eye on your AF numbers. If they do ok at 5psi but cant keep up at 7psi then I would go with larger injectors to decrease the duty on them.
1 - 2 of 2 Posts
