1 - 6 of 6 Posts
can i still buy from the dealer?
any short shifters out there?
my shifter is very bad
thanks for your help
by "my shifter is bad" do you mean its sloppy? or is it grinding or what? try to be a bit more specific. if its shifting sloppy, try looking up BillyM's bushing kit. from what i read on here, its quite easy to do yourself, and really makes a difference in the tightness of your gear pattern
If you put your shifter into any gear and have more than 1/2" of movement side to side, you have a damaged shift socket, and it can cause all sorts of problems from slop to increasing difficulty in shifting into 3rd primarially and then other gears following.
A short shifter will not resolve the underlying issue, and you will have to either replace the shift socket with factory parts ($150+drop/split the trans) or a socket repair and bushing kit (such as what I sell), same result just two ways of getting it.
--billyM
Most every thread I found for shifting problems not related to transmission itself led to the BillyM bushing kit. I just received mine last week.
1 - 6 of 6 Posts
