1 - 5 of 5 Posts
Get a non-oiled filter...
FYI if your in Kalifornia you will not pass visual inspection for your Bi-annual smog
14411
check...
Easiest way is to remove the entire air filter assembly KEEP the rubber elbow from the AFM then adapt modify a filter to go on a short section of pipe... see pic for reference
14412
You can also get a K&N with a 3" clamp on mount and use a short length of 3" exhaust tubing between the filter and elbow.
Theres probably drop in filters available still too. Cone filters in the stock location end up sucking mostly hot air that's come thru your rad.
1 - 5 of 5 Posts
