1 - 20 of 39 Posts
Hey Billy,
Glad to see your made it home safe. I did some reading and something is up with my turbo setup. One guy who has the exact same JT-58 turbo makes 19PSI by 3800 RPM?! Also a couple of the guys who have the JT-56 are 15 PSI by 3200 RPM. I checked my log:
3000 RPM ~ 2 PSI
4000 RPM ~ 8 PSI
4800 RPM ~ 15 PSI
http://www.supramania.com/forums/showthread.php?98074-JT58-Series-Turbo-Questions
It is true Billy runs away from me until I get to 5000 RPMs. And my current redline is only 6000 RPM.
-John
3rd gear pull starting at 1000RPMs shows it only about 200 RPM sooner for all three marks reported above.
false advertisement until proven by video. lol
like you said, statement false until proven. haha we want video!
edit:
Also HP isn't everything. Acceleration is where you won :laugh:
Standalone right? Have you fully tuned the ignition and fuel maps? 4800 RPM at 15 psi is silly unless you have a big big turbo.
Discussion Starter #11 (Edited)
^ Fuel is spot-on, but has some conservative (not stupidly so) ignition maps.
Next step is to log the factory ECU (mine) for ignition angle under varying circumstances and then see where his maps differ.
It wouldn't hurt to see some other standalone 7m timing maps to boot....
*JP, where's our vids?*
--billyM
Discussion Starter #13
That is awesome! I don't need video proof, I just wish I was there.
Post dyno'ing 50ftlbs better than me, John was saying something along the lines of he would have no trouble keeping up on the dragon this time...
...so I'm seeing a re-match in the near future.
(If he gets that thing spooling right, I'm totally cheating and putting on R-compounds though...)
--billyM
That said, I'd start by removing the MBC and tighten the wastegate up until it holds 14psi or so...
see if that changes anything...
--billyM
This.....
Is that all the evidence you got, cause I ain't convinced.
No boost leaks, other than a tiny one from the PCV and another small one from the Idle Valve which I fixed. No difference. I'll check for exhaust leaks tomorrow, but no obvious signs or sounds. Wastegate is as tight as it will go and makes about 10 PSI, but no significant changes to boost curve. Turbo spins freely. <sigh>
-John
1 - 20 of 39 Posts
