When i did my cylinder head I had to disconnect knock sensor-Since rebuild Im getting check engine lite past 2000-2500 RPM-Pulls code 52-Knock sensor circuit-Before rebuild, no matter how bad it pinged, it never tripped knock sensor-Car is timed at 10 btdc, cams are indexed-Can you put that plug on backwards?-Is the plug under Intake/next to fuel filter the Knock sensor? I drove the car another 40 miles tonite- gonna drive to work tomorrow and see how it goes but so far engine runs good-Can you defeat sensor? tia-Mike p
