Hi folks,
Couldn't resist adding a post!
I have a JZX-91 Chaser half-cut in transit at the moment. The plan at the moment is:
BIG FMIC
with water spray
Apexi S-AFC II
Stoch ECU
3" custom exhaust
Chaser autobox with mild torqu converter for starters (at least until I find a 2JZGE W-58)
Stock turbos running around 10psi (will hi-floe & replace ceramic bits with steel later)
Electric water pump
Bosche fuel pump
Chaser radiator - or re-core Supra radiator
GFB Stealth BOV
Upgraded brake discs, rotors, lines and fluid - stock callipers behind
Stock wheels
Few other bits & peices I've forgotten!
Also having the interior re-upholstered right now - black & red to match exterior SDR.
Will keeps ya posted,
Justin
JZA-61 in the making
BIG FMIC
with water spray
Apexi S-AFC II
Stoch ECU
3" custom exhaust
Electric water pump
Bosche fuel pump
GFB Stealth BOV
Stock wheels
Justin
