1 - 17 of 17 Posts
My engine is a ~100k mile 6MGE which sat for 10 years during 2006-2016. It ran fine for 5 months after I bought the car.
I did a post a while back talking about how my 4th cylinder is not firing. It had 160 PSI of compression, fuel, air, and spark. Oil was getting into the cylinder and fouling the spark plug ( I believe). The spark plug would get covered in oil quick and the cylinder is also oily when I look down. After driving it a little, I am noticing a grey paste on the spark plug. I decided to do a leak down test and my gauge is garbage so I do not trust the reading. However, there was quite a bit of leakage coming out of the oil cap area. I heard it leaking (sounded louder than normal) and there was also smoke or something coming out. I did the same leak down test to other cylinder, and they had exactly the same result so now I am very confused. Why are cylinders that are firing just right also having the same result as the dead cylinder? I thought my piston rings might be bad but all the cylinder have around 160-165 PSI of compression. There is no air coming out of the intake, exhaust, or bubbles in the coolant in all cylinders.
My initial thoughts were bad oil ring or valve stem seal causing the oil to come in and foul out the spark plug. Not sure what to do at this point, might give the car to a Toyota dealership to figure out.
I would try an oil change using a quart of Marvel Mystery Oil. To see it that will clean the piston and rings to provide a better "seal"...
You're likely right about the oil rings, but that "grey paste" would make me nervous enough to pull the head and see just what is going on.
Did your car sit for 10 years outside? Or was it garaged?.
Can you post a picture of the spark plug?
There is an easy to use and free image hosting site.
https://m.imgur.com/
Discussion Starter #4
The car sat for 10 years under a cover, outside, in a drive way in Southern California. The engine was swapped into it by the father of the guy I bought the car from in the early 2000s I believe. The guy got the car running again in 2016 and put some miles on it and then sold it to me in 2018. It ran like new for a 2000 miles. It started misfiring so cleaned out the clogged injectors. When I put everything back together I forgot to put the distributor in with the right orientation so the car wouldnt start. I kept cranking it and eventually it started, then I realized the timing was off. After correcting that, I noticed cylinder #4 was completely dead. It wasn't dead, or as dead, before. Heres a photo of the oily spark plug. I do not have a photo of the grey paste... The grey paste was mostly on the bottom threads of the plug.
Photo #1 shows a dry plug before I put it in that cylinder.
Photo #2 shows that plug after I ran it in the dead cylinder for a minute covered in oil. You can't see how bad it is due to the shade.
photo #3 is a old photo of the dead cylinder before the grey paste started to appear.
oil1 by Shyzah, on Flickr
oil2 by Shyzah, on Flickr
Cylinder 4 and plug for 4. by Shyzah, on Flickr
You are going to have some blow by even on a new engine and we aren't hearing what you are hearing so its hard to say, but if the numbers on the gauges are right, then its not a compression problem. An engine can be burning a "lot" of oil and still run perfectly smooth so I don't think oil fouling the plug is the problem.
I may be way off, but just trying to reason this out so follow me for a moment. I am imagining a car that sat for ten years, maybe you got it to run for a while, but eventually a "chunk" of 10 year old congealed gasoline dislodges from somewhere after the fuel filter and wedges itself into fuel injector #4. You did say in the previous post that you found yellow flakes in the fuel rail. Maybe there's more where that came from. I could imagine a dribble coming out of an injector instead of a spray so no air/fuel mixing and thus no firing. Maybe instead liquid fuel is washing the oil off the cylinder walls and intake valves, splashing round the cylinder and onto the spark plug. Now imagine an oil/fuel mix like in a 2-stroke being partially ignited on the electrode but not explosively like its supposed to, rather more like a smoldering fire. Only its not ashless 2-stroke oil, its motor oil. So now you got oily, grey ash on the spark plug. Maybe the problem is still in the fuel delivery to Cyl #4.
Or it might be similar symptoms if say the spark plug is only firing one out of every five compression strokes. If the fuel/air mix is not burning, then eventually it builds till its "wet" in the cylinder, washing the oil off the cylinder walls and same thing happens. Plug finally fires once after ten tries and because the plug is wet with a fuel oil mix, you get ash.
Discussion Starter #7
@wagzilla I didnt put any antiseize on the plugs. Ive been through 3 plugs on that cylinder and never saw that paste before. Just saw it after driving the car 6 miles to a car meet and back on 5 cylinders lol.
@pdupler That's why I'm so confused... there is nothing wrong with that cylinder that would cause it to not fire. The valves were perfect from the leak down test. Maybe it is fuel delivery. Is there any way I can test the fuel delivery into that cylinder? I know the injector is good. Had them cleaned and tested by a company. Only thing I can think of would be, like you said, something in the fuel rail that is doing something. At the same time, how can something that large flow through my fuel rail and block off only one cylinder? Also, when I took the injectors out for the second time I ran a brush through the fuel rail making sure there wasnt anything large down in there.
Do you guys think this could be a computer related issue?
I honestly don't have any time to work on this thing with college and the last thing my parents need is my car torn apart in their garage for 3 weeks so maybe Ill just give toyota the $135 to try to figure out whats wrong with it?
Toyota is unlikely to even know what one of these cars even look like. Did you ever pull the valve covers to make sure the valve train is correct? You can easily check injectors by shuffling them around and seeing if the problem moves. Fouling the plugs from oil takes time so a new set of plugs should work for awhile. If you have a ring or valve stem seal problem the car should be smoking out the tail pipe. You'll get a bit of leaking since the rings aren't a perfect air tight seal.
If the problem suddenly appeared after working on the distributor I'd suspect thing in the area, wires, caps, etc.
The grey stuff does look like antiseize compound. Looking at the pic you attached with the oily cylinder, I think you can see that same grey stuff on the spark plug threads. you may have brushed against the threads while installing/removing the plug?
Seems like I remember someone posting on here about how they set up a rig to test fuel injectors so they could see the spray pattern and measure the flow. I'm sure there's probably youtube videos, but while its conceptually simple, that's spending some serious time to make a tool.
It is possible that its a computer related issue as the computer controls the injectors, but it could also be a wiring issue. Maybe the wiring or connectors between #4 and the ECU is compromised somewhere. The wiring harness is surely quite crispy after 36 years and every time you touch it there is some risk. You'd need a simple noid light to check to see if the injector is getting signal.
Discussion Starter #11
I'll pop the valve covers soon to check the valve train.
I tested the wiring a while back and it was fine. I was getting around 12-13v out of both of the injector wires for that injector. (To get that voltage, I hooked up the + from the multimeter to the fuel injector wire and the - to the - terminal of the car battery).
Maybe I should just get a noid light to double check if its blinking. Also swapped injectors around and it made no difference. I know someone with a spare ECU, gonna swap that in to see if it makes a difference.
Just sharing. Had dead cylinders as a result of plugged injectors three times in a row before i cleaned the fuel tank out using electrolysis and a sacrificial anode to clean the tank. My car sat for about ten years as well before i got a chance to start working on it again. Gas(ethanol laced formaldehyde is what it smelled like) was whiskey colored when i poured it out. Tank wasfull of rust. Needless to say i can dissassemble the intake rather easily in a small amount of time now. The picture is showing the inlet on the left injector "last chance filter" plugged with rust debris inside the injector inlet. I just cleaned with injector cleaner by holding them upside down and spraying into it with fuel injector cleaner.
Sorry, disregard my post. Saw now you swapped injectors already. Thanks
That's OK. The OPs didn't specify in what order he did injectors in relation to other things so may still be the issue. In any case, its a good reference for the next person who finds this thread looking for answers. I expect as these cars start to become collectable, there will be more people trying to resurrect one that's been sitting for decades.
Now that you have posted up pictures I do think you're right on the money with the bad oil rings. If the engine does not have a ton of miles on it, there is the possibility that the bores are still square assuming it's never been re-built.
If you're familiar with how to check the bore for run-out and wear then this is actually something you can do simply by pulling the head and rotating the pistons to the bottom of the bore. It will not show you the entire bore, but here are some things you can look for.
The XXXXXXXX pattern in the bore is stock from Toyota, aftermarket machine shops and some guy with a dingle ball hone can also duplicate this; that's why it's not always the best way to see if a cylinder is any good. This is why you measure the inside of the bore both at the bottom and the top in multiple areas not just side to side, but also front to back and at an angle.
This will show you exactly how round the cylinders are, in turn how well the rings and pistons will seal. (Write down your figures and check the toyota specs on this to be certain things are in tolerance)
If you open the engine and do not see that XXXXXXX pattern on the cylinder walls, then the bore is worn badly and the oil consumption / smoke is just a byproduct of this.
If the bores are round and still retain the XXXXXX pattern then your oil rings are stuck, and likely due to corrosion.. There is no sure way to fix this, but there are few things you can try to remedy the problem.
Drain the motor oil, and poor some kerosene into the cylinder while its 3/4 to the top, and rotate the crank to move that piston down and then back up; this allows the kero to get down into the rings and maybe clear it. You can use other penetrating oils if you like, I have had luck with good old kero tho..
Best possible solution to stuck rings is to pull the motor, and replace the stuck rings and any worn components that can and will cause you grief later. I strongly recommend to just rebuild the engine if the rings are stuck, it's the best possible outcome later when you're not stranded on the side of the road for "Reasons".
This way you know that the engine is in good condition, all the bearings are good, there are no clogged oil passages, no stuck rings, no blown head gasket, no bad oil pump, etc.
Discussion Starter #17
Been busy working on body work for this car so I had a toyota dealership look over it for $98. I'm actually starting to believe that my engine is fine considering that this happened right after put everything back together. I even had Toyota master tec from the local Toyota dealership look over it and they said that the engine looks fine. They did a leak down test like I did and they said that it seems fine but they cannot guarantee anything since there was a coolant leak from the thermostat housing as well as that upper engine coolant hose towards the back. They wanted to charge extra to dig deeper so I denied. He too said that everything seems fine and if there was a slight head gasket crack or oil ring failure that it would not cause an entirely dead cylinder.
Do any of you know if the firing order for a 6mge is two at a time or does it fire all injectors at once? I read somewhere on the forum that the 5m fires all at once. I am guessing it should be the same for the 6m but I just wanted to confirm.
1 - 17 of 17 Posts
