1 - 3 of 3 Posts
I have an 85 supra and the sunroof leaks when it rains, but only when i move the car when it has been sitting in the rain. I seen online somewhere that alot of sunroofs have a drain system that can become clogged and cause this problem. I am not sure if my car does so any clearing up there would be nice, and if so how can I unclog it.
Yes, it does have four drains. One at each corner with vinyl tubing that goes under the car for drainage. The two in front go down the A-pillar and behind the kick panels into the frame underneath. The rear ones go down the C-pillar and end up underneath the hatch.
If you open the sunroof you can see the front ones in the corner. The rear, of course, cannot be seen and are typically the ones clogged with leaves, etc. you can try sticking an air hose to them and you may get lucky but one usually has to drop the sunroof pan and clean them out. All in all it is not a difficult job.
1 - 3 of 3 Posts
