21 - 40 of 1213 Posts
Discussion Starter #21 (Edited)
I've had a little time here and there to remove the dash and some of the components underneath:
Today I took a deep breath and started the rear wheel well project. It's going to be a long process! I removed some riveted and sealed sheet metal. It was keeping water out but I need the area to be structurally solid to take hours of racing. I'll be learning to weld soon...
Passenger side:
And driver side:
Thanks to a couple of threads in this forum the damage doesn't seem so daunting, but it's going to be a challenge!
Ugly!!!!!
Passenger side:
And driver side:
What an ugly patch job. Looks like that is a common area for rot huh? Go get an old fender and learn to weld on that before you tackle this mess. The steel they use is very thin and can be tricky to get a good bead. Low heat and practice my boy.
Good Luck
Discussion Starter #24 (Edited)
Thanks for the moral support! It gets easier to look at each day, and with more reading in the restoration threads. Our current Lemons car will be donating an old hood to be cut up and used as patches. Today I started cleaning the mess.
There's actually some metal in there!!
Discussion Starter #25 (Edited)
I decided to tackle the worst wheel well first (Driver side). As you can see after some clean-up, the inverted bowl that houses the top of the spring is missing a large piece. It's thicker metal than the body panels, so my first job will be to weld in a patch to enclose the spring using 1/8". I also asked a couple of my friends about welding patches from the bottom as I've seen in a CS thread. They said it's not fun to weld upside-down, so I'm going to tackle the large patch in a different way.
After removing old riveted patches:
Basic clean-up with wire wheel and cut-off wheel.
Due to the extent of the damage I decided to take a slightly different approach for the sheet metal repair. The cross-brace is in excellent shape, and is spot welded to the original panel... well, it used to be spot welded, I drilled them out. This will allow me to tuck a large patch between the brace and the current panels. Here is the first attempt at starting a template.
And the 2nd attempt
So yeah, I'm basically rebuilding the entire wheel well and suspension support.
Discussion Starter #28 (Edited)
Still in the disassembly stage. I've been removing things that don't affect the car sitting outside in the rain (rear wiper motor, control units for door locks, entire exhaust system, unnecessary switches and wiring, etc). I can't wait to start removing windows and gutting the doors, hatch, and hood, but that will have to wait.
A friend showed me an easy way to remove the "Black Goo" insulation on the floor pans and tunnels. Dry ice is the secret. Use pellets if they're available, spread them onto the goo, let sit for 5 minutes and PRESTO, the stuff come up in chunks with a tap of a hammer and chisel.
NOTE: Don't touch dry ice with bare hands. I got mine at a local grocery store - about $15 worth did the entire job.
I wish that I had saved all of the insulation that was removed, it had to weigh in excess of 15lbs. Here are a a couple of views of the chassis.
I also found a 1986 Cressida in a local Pull-a-Part and scored some front hubs with good bearings to complete my "BBK" parts list. $30 for both.
I'm considering going back to PAP to retrieve the entire rear subframe including suspension (they want less than $200 and mine is very rusty). I hope everything I read about the Cressida and Mk2 Supra being identical is true.
Discussion Starter #30
Thanks, Rob! It's going to be a slow process with all of the welding that will be necessary(and me just learning to weld). Having the car in the driveway makes life easy - I work on it when I have free time. How's your build coming along?
I'm with you on the welding . I just paid someone to do mine - camber brackets, sway bar tabs and my front coilover setup. Its moving at a snail's pace but some progress is better than no progress.
There are a couple of MkII Crapcans running up here lately. We ran with one in Portland in the spring (it was relatively fast as well) and I heard rumor of one running the last Lemons race at the Ridge. Good luck with the build!
Discussion Starter #34 (Edited)
Is that a white MK2 supra in front of the Mk3? I heard that the Mk3 was drifting that corner for the final 10 minutes of the race. We usually don't have enough tire left at the end of a race to attempt shenanigans like that.
In other news, my build may be heading in a new direction. Will have more information tomorrow, but here's a teaser:
After all that work you decided it was too far gone?
-John
Discussion Starter #36 (Edited)
-John
The deeper I got into the disassembly the more problems I uncovered. The blue car in the photo is only a shell, so the heart of the black car will still beat in this Lemons build. I know my limitations, and the work it would take to make the car structurally safe is beyond my skills. One advantage to the swap is that I'll have some spare parts to take to the track for the inevitable repair.
That car looks Familiar.
Discussion Starter #40 (Edited)
A HUGE thank you to Atl Racer for contacting me at the end of a very frustrating day and offering to sell me the shell. The blue car is exactly what I need to keep the build moving. I shall name her Supra 1.5 since it will soon have the other engine and trans bolted in.
Here she is arriving home:
I couldn't wait to start removing things, and you can't imagine my attitude change when I saw this:
If you have the stomach for it, go back and look at the same areas in the Black car...
If everything goes well, she may be at the next CS.com meet at this place:
The black car will be completely stripped and sent to the scrapper. I feel bad doing this, and hope that the parts I remove can find new homes. Until then I'll be updating my Lemons budget spreadsheet, revising my "to do" list, and dropping the entire Fr and Rr suspension.
