1 - 19 of 19 Posts
what would be the negatives of a supra with lowered front springs like eibach and the factory springs on the back?? handling issues??
as well as a very awkard ride, it turns the front tires into a fulcrum everytime you hit a bump
Greg G's car has stock rear springs and eibachs in front. Looks good to me. Tokico struts in front help raise the front a smidgen to even it out.
I too have been curious about this as I have been stumped on what to buy/install for front and rear.
I want to maintain a fairly stock ride height, however, I wouldn't mind the front being a tad lower (1/2 at most would be ideal for front) to even out more with the stock rear height. Now I'm just trying to figure out the best spring/strut combo for the front as well as the best spring/shock combo for the rear to accommodate this.
Any suggestions on the best set up to get what I'm after? I would love to see a stiffer spring rate front and rear. There are so many variables going into this since I am relatively picky on what I want the end result to be that it is overwhelming. I thought I wanted KYB or Tokico fronts, but not sure which. I know I want KYB gas adjust rears, and I am totally confused as to which will make me happiest when it comes to stiffer springs with a stock rear height and slightly lower/stock front.
Thanks in advance!
I would imagine that as long as you have good struts/shocks, preferably adjustable, that you won't notice much different for street driving. Personally, I think a bit of rake vs. the stock heights will help handling a bit. Just lowering the front may make the front feel more responsive, accurate, and of course, stiffer. I wouldn't be too concerned about understeer, for now, lot's of owners think the cars oversteer too much anyway.
If you want to lower the rear a bit (and most owners won't due to increased camber) you could always get some stock rear springs and cut them maybe 1/4 coil shorter. Cutting springs kinda stiffens the resultant spring, but again, there are concerns about lowering the rear. Just make sure your alignments are good, whatever you do.
Don L.
Im running a lowered front on coilovers on stock rear setup.
Drives just fine. Handles good.
Will handle better when I get better shocks and struts (gr2s blow even tho they are new).
I will probably be cutting a tad out of the rear for a little bit till I decide to get new springs.
I'm running Eibach in the front, and converted to stock springs in the rear (picture below just after the conversion).
I guess since I am old school, aesthetically I prefer this stance on the car over fully dropped. Also, since I don't push this car much (it's a daily driver), for street driving understeer as a result of this stance, is not an issue.
The only difference that I noticed in going from back to stock from Eibachs at the back, is that the rear is a little more bouncy on bumps (Eibachs were obviously stiffer - and maybe just the right spring force).
I use to run ST springs all around with a spacer in the back to lift it to stock height. I personally liked that set up, till I went with front coilovers.
Currently using ST front springs and stock rear.. matches well. No issues at all with increased spring rate in front.. the increase is minimal.
That sounds like what I am looking for. However, I do want a stiffer rear spring, just stock height. What are you guys running for shocks/struts?
you can see in my signature, my l type with lowered fronts and stock rears
whilst it mightve had something to do with the stock suspension in the rear and the firmer upgraded suspension in the front, i wouldnt recommend it if you like to do abit of spirited driving.
Whilst racing a gt starlet i needed to pull up from 180kph in a hurry, the rear end got very hairy under braking.
not cool.
Never liked the eibachs. Didn't lower the front at all for me...and most I see the front still looks stock height. The rear dropped but not the front...wtf?
Had em on a week and took them off...went with the ST's all around-perfect.
Yeah, Kayaba GR-2s are comparable to Sensa-Tracs (which I put in the rear a couple years ago), but KYB are better in that they handle other suspension mods like lowering springs better.
I've read about people having issues on Sensa-Tracs, but they work fine on my L-type (stock springs and 225/60 tires in the rear) - no rubbing even without flares.
Dobinson lowering springs and Tokico struts, 195/70 tires (on the front) got the stance where I wanted - more positive steering/cornering, good for my daily summer driver.
Back on the road soon! D-10 and counting...:mk2_vroom
1 - 19 of 19 Posts
