My 85 has 182+ on it and i've "never"... had a problem with the engine. but yesterday i lost all oil pressure opened the hood and a huge cloud of white smoke came from the engine compartment. The whole under side of the car was covered in oil alone with the entire passanger side of the engine compartment and engine. I checked the oil and there was none. I added 5 quarts in and nursed it home. When i got home i checked it again and there was NONE it drained 5 quarts in less than 5 miles. What could have caused this? I riped apart the right side of the engine, took out the intake and the MAF sensor and pracket checked all the pressure lines and did not find a problem... Could it be a head gasket, or value cover gasket (the thing where the cams sits)? I would realy appreciate the help! my landlord said I have untill the end of the week before he pushes her out the garage and sets her on FIRE! :shock:
Plus I have eibach spring, KBY shocks, Goodridge Stainless brake lines, and a Doug Thorley Header to put on. not to mention a ACT cluch and a Fidanza Aluminum flywheel already on her
