1 - 5 of 5 Posts
I have had a lot to deal with here in the last few months. I am forcing myself to get to the garage and get stuff done..
I found out how hard it is to work on the turbos! So many bolts, hoses and pipes.:eekfacepalm:
Wiring 80% done
Y pipe installed it was much lighter than the oem pipe.
R154 installed Thanks to parts from Mark!
2J pump installed
What is this hole for?? What am I missing?
Also what trans mount to use on the 154 the stock 154 on my auto xmember?
Power steering pressure line will the RA65 work?
I need to figure out the fuel line stuff using a A1000 Aeromotive pump. Any ideas?
About 1 to 2 months for the final drop into the bay. ( I usualy only have sat to work on it):SM130 (1):
If everything goes good maybe a start up video in spring.
I used a trans mount from an auto Ma61
You will need to make your own PS line. heres mine...
A1000 pump would be overkill but I assume it would work just fine, there are other external pumps that wont cost as much or be as load as a A1000 but still pump more than enough fuel for a stock 1J. But either way I dont know if you could even use that pump withought using an AFPR.
Looks good so far! Good luck!
I need something to go in the hole, LOL! I dont need the abs I am using a JZA70 ecu.
Also the A1000 I will be using a fuel press regulator. My pump is a rebadged A1000, Paxton brand. Got it for cheap. It has 10 an in and out was going to adapt it to 8 or 6.
1 - 5 of 5 Posts
