Awesome! Can you please do me a favour though, could you measure the displacement of that rack per turn? I currently am running the stock rack depowered, and to be honest it isn't that bad for effort now (now that I got all of the fluid out of it). I think a true manual rack may be a little easier to turn, but its not so bad that I'd be willing to sacrifice my steering ratio any. I have the Celica GTS steering arm mod already of course, but I'm greedy and still want a better ratio. Conventional logic says an auto manufacturer will use a slower steering ratio on the manual steering version of their car to make it easier to turn, so my thought was the RA65 Celica power steering rack would have a faster ratio then the manual one you have there. I have 2 of these, and I finally got around to comparing them to a stock Celica Supra rack. I always wondered why they even bothered having 2 different racks and if the ratio would even be different as the steering arm lengths are dramatically different. I took a bunch of measurements, and lo and behold, the RA65 Celica power steering rack has a different ratio, a different max angle and looks like it will bolt in to the Supra. However, everything was worse. Here's the measurements I got...
___________________USDM MA6x Supra______USDM RA6X Celica GTS
Turns Lock to Lock____3.1__________________3.2
#of mm's displacment
per 1 complete turn ___52mm_______________45mm
In addtion, the 2 racks appeared to have the same length\track width, which one would expect considering the cars basically have the same track width. However, the Celica Supra rack has significantly more extension at full lock, giving greater steering angle. So the Supra rack would be a pretty decent upgrade on a RA65. However, if the manual rack for some reason has a better ratio, I'd be all over that. So if you could please lay down a tape measure, find something to measure from on a tie rod end, perform exactly one rotation of the input steering shaft and then measure the displacement, that would be fantastic. I can convert from inchs to millimeters if need be
(1inch = 25.3mm)
