1 - 6 of 6 Posts
'85 Toyota Celica Supra P-Type
added more coolant today and tried starting again
will not stay running and not sure if I broke something else
uploading a video to Rumble and will share here:
sent using Tapatalk
Was it running with no issues before you did all the work? If so, I would double check all your vacuum lines and intake piping. You may have a vacuum leak somewhere.
Reactions: JCC
yes, it ran great as far as I could tell
will keep digging
come over and I'll bring the barley pop haha
sent using Tapatalk
fuel starved? and chance you pinched a fuel line? Fuel filter is cheap... Try removing the fuel filter and blowing through it, shoud be fairly eazy to blow through.. also check for "mud" in the filter
Reactions: JCC
Discussion Starter · #5 · (Edited)
very well could be fuel starved
I will need to locate the fuel filter and trace the line
sounds like it is having trouble on the exhaust end also
sent using Tapatalk
Your Cold Start Injector time switch fucked-up wiring could be part of your start-up issue.
Reactions: JCC
1 - 6 of 6 Posts
