1 - 14 of 14 Posts
My Supra's sensor light just turned on for the first time while driving to work yesterday. I'm assuming it means the the O2 sensor needs replaced but wanted to double-check before picking a new one up. Anyone else have this issue? Funny, I've never had a light turn on with this car.
Discussion Starter · #2 ·
Well i went ahead and bought one from RockAuto. For $22 bucks i figured what the heck. Any tips for getting it off without breaking anything? Bolts look clean so i'm hoping it will come right out. Kind of a tight area though. May do some knuckle busting.
Replacing the O2 sensor on mine did not fix the problem. I seem to remember reading that there is a reset button or switch under the driver side dash to reset the light. It's been a while since I drove or did anything with my mki so I don't remember the details.
Instructions are in the Supplement for Supra Chassis & Body Repair Manual...Section 4-4
I'll try to post a pic...
1979-1980 Model
Cancel switch on the brake bracket
1981 Model
Cancel switch is on the upper left cowl trim board near (left foot area)
MGSS Afflicted
1985 Celica Supra P-Type; 1979 Celica Supra; 1992 Supra Turbo Targa 5spd; 1998 Supra TT Targa 6spd
What AJ said. Goes of every 30000 miles whether you need a sensor or not. Small 2 position switch up high under the steering wheel
Reactions: AJ
And replacement O2 sensor/reset procedure in the Toyota Maintenance Procedures 1980 Models Section 7-15...
Reactions: ddd228
AND more pics...
Excellent, thanks for the info everyone. I'll try this first and stick the sensor in the parts bin if not needed. Great news.
For the 1980 Mk1 but may apply to other years as well...
Try resetting first…
Only 100% sure way to test is analyse output with oscilloscope.
Not many people have a scope handy.
Wouldn't a good DVM properly measure the DC at 0.45V, AC at 0.20V.?
DC +/- for rich/lean, and AC for signal strengh
1 - 14 of 14 Posts
