1 - 4 of 4 Posts
Hey all, this might be a dumb question but does anyone know if the tie rod end/idler arm etc. fit on my supra? I need to replace the right one on it and i can find plenty of replacement parts for the celica but none listed specifically for the supra. I'm tempted to just buy them and give it a go, but figured I might as well ask first. If they do not fit, does anyone know where I can find some? TIA
Well, I don't know much about the MK1, but seeing that no one else is stepping up, I'll give it a go. Don't sue me if I'm wrong!
The Toyodiy.com web site shows that a 1981 RA43 Celica Liftback
http://www.toyodiy.com/parts/p_U_1981_TOYOTA_CELICA_RA43L-BCMQSA_4505.html
has the same parts as that of a 1981 MA46 Celica Supra
http://www.toyodiy.com/parts/p_U_1981_TOYOTA_CELICA_MA46L-BLMQEA_4505.html
There are date code breaks so that you should enter the specific model you have on this site to bring up the correct configuration.
This site is not a listing of currently available parts, but it is pretty accurate in terms of what the part numbers for each vehicle USED to be when they were available.
You can then check at a Toyota parts department to see if they are really available.
I hope that this helps.
Dale
MGSS Afflicted
Rockauto shows the same numbers for multiple models for the outer tie rod end and idler arm
TOYOTA CARINA 1972-1973
TOYOTA CELICA 1971-1981
TOYOTA COROLLA 1971-1982
TOYOTA CORONA 1974-1982
TOYOTA CRESSIDA 1978-1984
TOYOTA VAN 1984-1985
1 - 4 of 4 Posts
