1 - 2 of 2 Posts
After replacing/rebuilding OEM N/P 83 5mge alternator several times due to Diodes or IC Etc..
GM SI 65 Amp Alternator works and is less money also readily available.
Used Mr, Gasket Chev Alternator bracket #9850 lines up both V-Belts
utilizing stock tensioner.
83 P Type 5mge almost stock (Gm Alt) some running gear upgrades
83 L Type w/Mustang 351 v8 and T5 spd conversion
You can also use the 140A CS144 alt and small modification to the upper alt bracket and some washers on the lower bracket and both belts line up too.:thumbsup:
1 - 2 of 2 Posts
