The sunroof on my 1982 Celica Supra is off its tracks and makes a real bad motor noise. Just wondering if anyone knows how to put it back on it’s tracks? I heard I have to take the headliner off to even get to the roof.
Try some searches, this has been covered many times in the past here. Its likely the plastic brackets the sunroof pivots on, they are built into the rail tracks and tend to break if the sunroof gets impacted or forced. There has been some attempts to get replacements made, not sure what state those are at. There is definitly a thread about that (SupraZ posted it).
You've got to pull all those 10mm bolts out and lift the sunroof out from the top. The plastic parts that breaks rides inside that aluminum rail you can sort of see from the side. You'll have to look, but there shouldn't be any broken plastic on either side.
I see, so we are talking about the golden bolts? Also I heard that I have to place the rod back onto that black track as it seems to be under the track. Thank you!
My sunroof has been in and out twice to get the car resprayed, but all the parts are intact and it works fine. That being said, if you are able to get the parts 3-D printed, I would be glad to share expenses and have a spare set for myself.
If V.B. is still following this thread and has not gotten it figured out yet, you don't have to remove the whole head liner, just the trim piece around the sunroof, and the piece on the sunroof. Getting the headliner piece off the sunroof is the most difficult part of the whole process. If I recall, it has to be popped off on the front and then it slides forwards. That will give access to all the bolts and the cables. Make sure to make a note of the number of shims on each side for proper reassembly.
i might be making some aluminum pieces for the sunroof cables, the little plastic piece that breaks. i always have wondered why thy are plastic. but i need to know how many people would buy them before i get some made up? i dont know how much i will sell the pair for at the moment i will get...
Related Threads
Toyota Celica Supra Forum
946.7K posts
22.7K members
Since 2003
