61 - 65 of 65 Posts
Just got mine in from weir! Can’t wait to update you guys. Getting excited for the build!
Oh interesting.
The rear wheel bearings set the preload with a crush sleeve.
From that thread it looks like they figured out a 7.5" solid pinion spacer might work.
Though I see no mention of the min OD that will still fit over the hub.
Hard to say if a 30mm solid spacer will fit without modification over the hub.
Even if you used a solid spacer when doing new rear wheel bearings I don't expect many shops willing to put in the time to install correctly.
They would need to dissassemble and re-assemble at least a couple times to get the correct shim stack and measure preload.
Setting up a solid spacer correctly is quite time consuming, but once you get it...man is it good. :D
Hey Brother my name is Carlos Aponte
just saw your post on the LSD diff work for the 85 supra that you did and im impressed with your work,
i own myself some supras and im interested in rebuilding my mk2 diff i saw in the post that you work on them but not sure if you still do,
if so please contact me via txt/call at 718-570-1358 or email [email protected]
thanks hope to hear from you soon (y)
61 - 65 of 65 Posts
