foonanas said:
I was checking in on my 86 and found some moisture around the pass side of the spare tire. Anyone have a problem with this? only rust is in the corners of the hatch and it's not that bad yet. Thanks god!!!!
Well... It's quite possibly what others have suggested, a leaky hatch window. However, last year when I was restoring my '86 supra I gutted everything in the rear of the car. This meant removing screws that were screwed into the floor of the hatch. This left small open holes in the floor od the hatch. One day I looked in and noticed water all over and i was wondering if I had a leak. Then a realized the water was just spashing in through those tiny screw holes. So, I guess the first thing I would ask you is, have you removed any screws from the hatch floor?
The other thing that has caused moister build up in the rear was when my rear window washer sprayer hose somehow disconnected from it's fasteners. When I tried to spray the washer fluid on my hatch window nothing sprayed onto the glass, and a few seconds later I noticed liquid dripping from the ceiling. That too could be a possibility of where moisture is coming from (possibly leaking down the C pillar into the hatch).
- Mike
