1 - 5 of 5 Posts
Maybe someone has installed 6BTM to 83-85 5MGTE
Please help me to find out what is wrong with my setup
I have connected the unit exactly as msd manual says and used 8910 hei tach adapter
Engine starts okay, works ok and smooth
but as i stop it, it may not start again. I could crank it few times with no result, but after a while it starts and works okay again.
if i terminate 6BTM module (use only stock ignition) engine starts every time.
And also when 6btm connected i have strong interference with radio - it gives high frequency tones to speakers.
What might that be?
I have found on 8910 manual that we may require diod assembly to make the tach work - can such a diod help with it?
Please your suggestions
-Tony
Does the tach work? Sounds like you just have bad connections. Did you ground it to the battery or the chassis?
Discussion Starter #3
yeah
Everything was done right - all woks good when it works, including tachometer
All connections was checked carefully twice))
maybe old type of tach adapter is the point?
I have 8910 HEI
in 6btm manual stated 8910 EIS
actually i guess this is the same...
Bad ignitor or bad coil??
Discussion Starter #5
nope
with stock ignition all works
I dismantled system and found selecting loop uncut ( there are two loops that need to be cut when you select number of cylinders of engine)
i will check this in the nearest time, but i think this will change nothing.
And i am afriad i have burnt the module during my tests - maybe somebody knows where there is an internal fuse?
I tested 6BTM according manual - with tapping white wire against the ground - it was ok, after i add the tach adapter to scheme - no more spark from coil wire, than i deleted the tach ad again - and no life inside 6BTM at all((
1 - 5 of 5 Posts
