81 - 93 of 93 Posts
Discussion Starter #81
Discussion Starter #82
Have you owned anyone on the streets yet??
Not really but I did pull away from a 350z after he jumped on the throttle on the highway. Pretty sure he tried to keep up for a few gears
Discussion Starter #83
My 2JZGE build & swap thread
So the recent news is that I warped my head and the head Gasket leaked. As I usually do I freaked out and wanted to sell everything. Then decided to fix it. So I was able to buy a rebuilt cylinder head and I am going to start relaxing the head soon.
I figured this will give me a chance to make other things better any way.
Sent from my iPhone using Tapatalk
Discussion Starter #84
Wasting no time with this I just got new tires and an inspection and really want to drive my car. I was able to find a remanufactured head from a place in Florida .I should be seeing it early next week. I also ordered a new head gasket from Toyota should see that next week as well.
I started by prepping the operating room
Drained my oil and was really relieved to see that it had no signs of coolant mixed with it.
Did a compression test and came out with
#1-175 with oil on purpose
#2-115 oil not on purpose
#3-160 with oil on purpose
#4-170 dry
#5-180 dry
#6-180 dry
#2 seems is awful low so figure my problem is there. I removed the header and noticed a small bit of coolant residue on the #2 port.
In a couple hours time I ended up here.
Discussion Starter #85
Discussion Starter #86
Well the machine shop says it's ok to build. Going to order Pistons .20 over and standard bearings.
Discussion Starter #87
Wow I haven’t updated in forever. Umm where to start hahaha
Discussion Starter #88
So I ended up getting new pistons. I had a local machine shop rebuild the block. Bored out slightly over to correct cylinder scoring.
Got the block home and started to assemble it. Picked up a remanded cylinderhead and oem head gasket. I already had ARP studs.
I got the engine assembled pretty easily. And dropped er in. Took the time to wrap my header this time around.
Discussion Starter #89
I just got done reading your whole build thread nice, glad to see your back on it. I'm just starting mine, I know I have some fun coming up !!thanks for sharing
James
Discussion Starter #91
Thanks it’s been almost two years since it was done lol, just haven’t been on the forum since I was building it. Good job with yours !
Do you have any new pictures you can post
thanks for your time
James
Discussion Starter #93
Stay tuned going to update soon 👀
81 - 93 of 93 Posts
