201 - 220 of 237 Posts
Discussion Starter · #201 ·
Well, now that photobucket is back, I have already gotten a Flikr account, so am loading pics there. Long overdue. I probably am forgetting about some stuff. Since most of the questions I get are about my 8.8 swap, I will start with progress pics on that. Right now the big hang up is laser cutting. Place I normally used changed owners and now have a minimum order amount that is quite high. So if someone has a hookup on a GOOD laser cutter that will do small jobs for a fair price, I need stuff cut. Thickest will be 1/2in A36 mild steel.
I got the rear C7 ZR1 33 spline wheel hubs.
IMAG1071 by williamb82, on Flickr
IMAG1073 by williamb82, on Flickr
The 33 spline F250 front outer CV's fit them perfectly.
IMAG1067 by williamb82, on Flickr
IMAG1066 by williamb82, on Flickr
And the C6 12in x 1in rear curved vane rotors.
IMAG1076 by williamb82, on Flickr
IMAG1077 by williamb82, on Flickr
The template for the redrill jig I am building.
WheelHubTemplate by williamb82, on Flickr
The drill press walked on 2 of the holes. Luckily I only needed 3 of the 5x4.5in pattern. Has drill bushings for 5/16 pilot hole, then the finish hole size for the rotors, then the hole for the 14mm reamer for the hubs to ream them for the Toyota studs. I am going to a put a slight oversize drill taper on the 5x4.75in holes so the lug nuts will center it perfectly on the hub. Havent done it yet, My daughter keeps me busy. lol
IMAG1771 by williamb82, on Flickr
IMAG1773 by williamb82, on Flickr
Front caliper bracket for the 13.15inx1.25in curved vane Audi rotors I am using on the crown front hubs. I will use Wilwood Forged superlite calipers. I need to buy the calipers and have the center bore of the rotors enlarged still.
FrontCaliperBracket by williamb82, on Flickr
Custom machined bungs for the caliper offset. I tapped them to 7/16-20 for the caliper mounting, and the bracket is tapped for the stock brake caliper bolts. M12x1.25 as I recall.
IMAG1828 by williamb82, on Flickr
IMAG1829 by williamb82, on Flickr
IMAG1832 by williamb82, on Flickr
IMAG1835 by williamb82, on Flickr
Test fit on the RA65 struts. I will tig weld the bungs to the brackets, but want to test fit the rotors and calipers to make sure the offset is perfect before tacking in place to weld.
IMAG1840 by williamb82, on Flickr
IMAG1842 by williamb82, on Flickr
IMAG1844 by williamb82, on Flickr
IMAG1845 by williamb82, on Flickr
New front rotors next to stock front rotors.
IMAG0137 by williamb82, on Flickr
And next to the C6 corvette rears.
IMAG0139 by williamb82, on Flickr
Discussion Starter · #202 ·
I have drawn up the wheel hub mount, the caliper mount, and the jig fixture so I can build the new control arms. THese 3 pieces are what I currently need laser cut.
114_3patterns4and5 by williamb82, on Flickr
RearCaliper12inRotor by williamb82, on Flickr
ZR1HubMount120Wall by williamb82, on Flickr
I printed the hub mount 1:1pdf as the holes for the e-brake setup are offset. I got it perfect so the file is ready to be cut.
IMAG1888 by williamb82, on Flickr
I also picked up a 2JZ R154 bell housing with another OS Giken movement alteration kit. I got a "Built" R154 as well, though it has a broken second gear. I need to disassemble it so I can see exactly what needs ordered to repair it.
IMAG1755 by williamb82, on Flickr
Got the new shifter plate cut for the Ford T56 tailhousing so I can use my Hurst short shifter on it.
IMAG1761 by williamb82, on Flickr
Also grabbed a R154 output yoke for 1350 u joint, so I can run a 1 piece driveshaft with 1350 u joints when the 8.8 swap goes in.
IMAG1838 by williamb82, on Flickr
Also nabbed a 36-2 crank trigger for my 2JZGTE off of a vvti engine at the junkyard.
IMAGE0182 by williamb82, on Flickr
Found some center caps that fit my SSR's.
IMAG0026 by williamb82, on Flickr
IMAG0027 by williamb82, on Flickr
And got the proper decals for them.
30516228_10155059949531371_8877791692544016384_n by williamb82, on Flickr
Adjustable cam gears for the 7mgte.
IMAG1050 by williamb82, on Flickr
3T adjustable strut rods.
IMAG0978 by williamb82, on Flickr
Also got some rear springs in different rates to tune the suspension with. 600lb, 375lb, and I think the others are either 400 or 450lb. Thanks to Don Lew! I plan to eliminate the crazy squat under power.
IMAGE0050 by williamb82, on Flickr
And of course the 10AN oil feed line I will be using on the 7mgte rebuild.
IMAG1768 by williamb82, on Flickr
Discussion Starter · #204 ·
No. I wish I had a laser cuter, mill, and lathe. I got hooked up with a guy by the chimp to make the offset weld bungs that I tapped. Guy even had them bored to the exact size for my tap to go into after I told him what I was doing. I had drawn them with the hole slightly smaller so I could finish drill them myself with the right bit. I need a new hookup for laser cut pieces. All the local places I call wont do it because the order is too small. Its pretty annoying.
· Premium Member
Yeah, not having a "small order friendly" shop to use can really put a crimp in your fabrication plans.
I'm finally getting to meet some Real Car Guys here. One is a friend of the family, and works with his brother and Dad in the shop their grandfather built! They just installed a new chassis dyno, so I'm going to see how much they'd want to run the Supra on it. Might be interesting to see how much power I lost moving from sea level to 5000'.
· Whistles
Nice. Are you keeping the factory control arms?
There's a fellow building control arms from scratch in another section, and he's using Sentra hub parts. It seems a lot stronger than stock and he's got the jigs already done.
Also, why the 36-2 wheel if you aren't going vvti?
I've asked about using that crank trigger wheel for my setup for more resolution, but a well known tuner said it isn't needed and to keep the 12 point with Cam sensors.
Discussion Starter · #207 ·
More accurate, but also the 36-2 the teeth are part of the gear. The 12 tooth is a piece pressed onto the gear and is prone to breaking free. I can weld the 12 tooth on, but figure the 36-2 is just a better option since I will be using a standalone.
And yes, I am building new control arms. Similar to what Supersubs did, however I plan to use the stock spring setup instead of coil overs like he did.
Oh, and I got some rear camber brackets for when I mod the sub frame to mount the 8.8 diff.
IMAG1637 by williamb82, on Flickr
· Whistles
Building new from scratch control arms is definitely the way to go.
Same is to be said for the entire rear subframe if you're going for big power.
· Premium Member
Whoa, nice big update Will!
It is hard to keep things going with a wee little one that is for sure. I've been struggling to make much progress with anything project car related in the last year or two for sure.
Nice SSRs! Aren't you only going to be able to run 2 of them though? Crown stubs up front, Vette in the back, doesn't sound like you are going to have the same pattern front to rear.
Discussion Starter · #212 ·
Got the ZR1 rear hubs redrilled for 5x4.5in yesterday. Got the pilot holes in 1 rear rotor done, but had to call it quits due to the weather. I need to order the extended wheel studs, and then cut down the originals so they are flush with the rotor when it is installed, and of course, finish redrilling the rotors.
On the drill press with the redrill jig I built.
IMAG1986 by williamb82, on Flickr
5/16 pilot holes drilled
IMAG1987 by williamb82, on Flickr
Final holes for the studs drilled.
IMAG1988 by williamb82, on Flickr
Discussion Starter · #213 ·
Long time with no updates. Here are some updated pics for my custom 5 lug swap. I still need to get the center of the rotors bored to 76mm so I can finish the caliper brackets. I have the front and rear Wilwood Superlite calipers already, as well as the pads.
Crown 5 lug front hubs on the RA65 strut housings
Screenshot_20200331-194229~2 by williamb82, on Flickr
I got the rear wheel hub brackets laser cut finally. They fit the hubs and ebrake backing plates perfectly.
IMAG6085~2 by williamb82, on Flickr
IMAG6077~2 by williamb82, on Flickr
IMAG6075~2 by williamb82, on Flickr
IMAG6073~2 by williamb82, on Flickr
Drive shaft loop since I will be going with a 1 piece drive shaft.
IMAG6065~2 by williamb82, on Flickr
Brakes
IMAG5928~2 by williamb82, on Flickr
IMAG0099~2 by williamb82, on Flickr
IMAG0096~2 by williamb82, on Flickr
IMAG0095~2 by williamb82, on Flickr
Diff cover for the 8.8 IRS diff.
IMAG0134~2 by williamb82, on Flickr
IMAG0133~2 by williamb82, on Flickr
Reactions: ddd228
Discussion Starter · #214 · (Edited)
Also, finally building the engine. Still waiting on the ARP head studs I bought back in November, That is why the machine work has not been done yet. I did not take pics of all of the parts, but the major stuf is
83.5mm 9.1:1 Wiseco pistons
Eagle H beam rods
Trend 0.220in H13 wrist pins
ATI damper
Ported and polished head
BC 272 stage 3 cams
BC valve springs with titanium retainers
Ferrea billet valve keepers
1mm Oversized SS valves
Bronze valve guides
Gates Racing timing belt
HKS 2.0mm Stopper metal head gasket
Brand new Aisin 85 5MGE oil pump
Brand new Aisin 88 7mgte water pump
10AN oil pump feed
M20x1.5 to 10AN fittings for the oil feed pipe to block, oil outlet from the block, and oil main inlet
Technico torington bearing thrust plate for the oil pump drive gear
ARP main studs, plus 2 extra studs and nuts so I dont have to use the 2 bolts
ARP head studs
ARP insert washers for the head studs
ARP custom washers for the head studs. Full diameter of the relief in the head to disperse the load better. From SR Fab
Lots of new parts from Toyota. Water neck with banjo bolt, valve spring seats, tensioner spring for the timing belt, crank bolt, etc...
Adjustable fuel pressure regulator
Earls external oil filter mount
Earls external oil thermostat
30 row oil cooler
Walbro 525LPH Hellcat fuel pump (just 1 for now, but will likely add a second one later)
Tons of 10AN, 8AN, 6AN fittings and hoses for fuel, oil, power steering etc.. lines. Fuel will all be PTFE to support E85. 10AN feed, split to dual 8AN at the rail, 6AN return.
Lots of 4AN fittings and lines for the waste gates, boost control solenoid, BOV, etc...
3 row MK3 aluminum radiator
Aluminum shroud for dual 12in fans
Brass freeze plugs
Energy Suspension poly GM trans mounts for motor mounts
Lokar flexible dipstick. Havent decided if I will mount it in the block or oil pan yet.
New timing belt tnesioner tensioner
New 160deg thermostat
New aux shaft bearings
IMAG6580~2 by williamb82, on Flickr
IMAG6579~2 by williamb82, on Flickr
IMAG6578~2 by williamb82, on Flickr
IMAG6577~2 by williamb82, on Flickr
IMAG6266~2 by williamb82, on Flickr
IMAG6239~2 by williamb82, on Flickr
IMAG6247 by williamb82, on Flickr
IMAG6081~2 by williamb82, on Flickr
Bulkhead for the fuel pump outlet. 10AN to 1/2in barb. Barb is for the pump side. I actually have a 90deg one as well to use a straight fitting in case this will not clear the trunk floor
IMAG6034 by williamb82, on Flickr
IMAG5947~2 by williamb82, on Flickr
IMAG5946~2 by williamb82, on Flickr
IMAG5945~2 by williamb82, on Flickr
IMAG5944~2 by williamb82, on Flickr
IMAG5941~2 by williamb82, on Flickr
IMAG5940~2 by williamb82, on Flickr
IMAG5929~2 by williamb82, on Flickr
IMAG5914~2 by williamb82, on Flickr
IMAG5819 by williamb82, on Flickr
IMAG5810~2 by williamb82, on Flickr
IMAG5559~2 by williamb82, on Flickr
Discussion Starter · #215 · (Edited)
R154 rebuild kit with NSK and Niche bearings
All of the Marlin Crawler upgrade parts
Short throw shifter
1350 output yoke
OS Giken triple disc clutch
Front bearing retainer to fit an LS1 T56 throw out bearing
LS1 T56 throw out bearing I converted to -AN fittings
Misc -AN fittings, linesand a 3AN remote bleeder etc...
IMAG6669~2 by williamb82, on Flickr
IMAG5821~3 by williamb82, on Flickr
IMAG6654~2 by williamb82, on Flickr
IMAG6657~2 by williamb82, on Flickr
IMAG6662~2 by williamb82, on Flickr
20160320_141058_zpsijtokjia by williamb82, on Flickr
20160320_140535_zpsv4q8ab8z by williamb82, on Flickr
20160326_121423 by williamb82, on Flickr
Discussion Starter · #216 ·
Front facing intake from Thailand, 90mm throttle body, and my 4in HKS mushroom filter. I already had the alternator drop down bracket.
IMAG4521 by williamb82, on Flickr
IMAG6311~2 by williamb82, on Flickr
IMAG6312~2 by williamb82, on Flickr
IMAG6320~2 by williamb82, on Flickr
IMAG6416 by williamb82, on Flickr
IMAG6423~2 by williamb82, on Flickr
IMAG6473~2 by williamb82, on Flickr
IMAG6475~2 by williamb82, on Flickr
IMAG6491~2 by williamb82, on Flickr
IMAG6492~2 by williamb82, on Flickr
IMAG6497~2 by williamb82, on Flickr
Discussion Starter · #217 ·
Here are some test fitting pics of the new turbo setup
Sound Performance F1 twin scroll manifold (has some issues I must fix myself as they refuse to, There will be a separate post about this later)
Borg Warner S366 SXE with 0.91 A\R turbine housing, which is machined for a 3in Vband, and compressor is machined down to the 2.5in Vband outlet.
2.5in Vband to 3in 90 deg cast elbow
two Tial 44MM waste gates
1.75in od Waste gate dump pipes
3in 2JZGTE down pipe
6 EGT probes
30deg 4in intake pipe to fit the HKS filter.
All vband clamps
IMAG6670~2 by williamb82, on Flickr
IMAG6677~2 by williamb82, on Flickr
IMAG6341~2 by williamb82, on Flickr
IMAG6342 by williamb82, on Flickr
IMAG6346~2 by williamb82, on Flickr
IMAG6033~2 by williamb82, on Flickr
IMAG6051~2 by williamb82, on Flickr
IMAG6107~2 by williamb82, on Flickr
IMAG6108~2 by williamb82, on Flickr
IMAG6245~2 by williamb82, on Flickr
IMAG6246~2 by williamb82, on Flickr
IMAG6293~2 by williamb82, on Flickr
IMAG6495~2 by williamb82, on Flickr
IMAG6498~2 by williamb82, on Flickr
IMAG6463~2 by williamb82, on Flickr
IMAG6485~2 by williamb82, on Flickr
IMAG6408~3 by williamb82, on Flickr
IMAG6421~3 by williamb82, on Flickr
IMAG6411~3 by williamb82, on Flickr
Discussion Starter · #218 ·
Discussion Starter · #219 ·
