101 - 120 of 147 Posts
Those carbs look trick. Are they tricky to tune? Seems to me you would need seperate egt's on each header pipe to get the correct burn temps. I do have a atmospheric pressure density program that might be handy for your tuning. PM me if interested.
Matt
hey will when you grabbed that fuel pump did you think about getting the oil pump drift shaft?
newer shaft's don't have the cam lobe on it to work correctly.. either that or it hasn't been machined into a lobe yet..... not quite sure.
but just a thought..
interesting build bud. cant wait to see what this come's out like w/ video's and some dyno sheet's.
oh yeah. i'll ask some vw' buddies and see if any have side draft 45mm carb's for sale.
Matt
Yes, sidedraft carbs can actually be a real PITA to tune and keep synchronized if you're not familiar with them. Much patience is required and mandatory. :) I had a good synchrometer at one time but it got stolen along with the rest of my tools earlier this year.
Discussion Starter · #105 ·
the 5m oil pump drive shaft has a lobe on it. we already checked this in daves garage. the 7m doesnt have the lobe machined though. this fuel pump is physically larger then a sbc pump so idk if itll flow enough or not. we will have to check it out. just havent had time. been on a diet all year and joined a gym a couple weeks ago tryin to bust the belly off and its working. best weight rreduction mod i can do for my cars as it will benifit all of them :thumbsup:
Discussion Starter · #107 ·
no. gude cams are stock cams that have been reground to a reduced base circle. i had a pair. sold them last year. if they were new why would they regrind them to a reduced base circle?
Discussion Starter · #108 ·
got a set of oversized ss valves for the head thanks to AJ. heres a pic of them. still brand new in their never opened packaging.
wow man, this project if f-ing awesome dude, I wish carbs like that were still availible these days for our Supras. damn I'm on the list of people that would like to see it run in person. :thumbsup:
Discussion Starter · #112 ·
the carbs never sold. all i was selling is the carbs as i need larger ones for this. carbs are still for sale. i need 45's. the hks stuff is not for sale.
Discussion Starter · #114 ·
it has to do with the cams and rpm range. im planning to rev to 7500-8k
So whats going on William? still got the 40s? Stock cams and head would probably be a good candidate, wouldn't ya say? Know any good sources of education on how to prep webers for boost?
Discussion Starter · #116 ·
the stock cams wont work. the rear of the hks cams are machined fro the rear cam mount ignition. the distributor will not fit with side draft carbs mounted. yes, i still have the 40's, and still plan to sell them so i can buy some 45's. as for boost, i will not boost this car. as for prepping them for boost, i have a couple books, i beleive one of them mentions it but i dont recall which one.
at this point, i need to have the head machined to fit the over sized ss valves, ive decided to have a 5m block bored for the 20 over pistons im using instead of using the 20 over 7m block. its a newer 5m block so shouldnt need clearanced, though if i can get ahold of eric ill see if i can talk him out of his actual 6m block. also, i need to send the hks cams to be repaired. i was quoted $200-400 depending on how bad they are. then i need a mhg and at least new stock head bolts, maybe arp head studs if i can get some the proper length. i wont use 7mgte studs. also plan to get the 7mgte rods reconditioned and arp rod cap bolts installed. i want to get a light weight flywheel for a w58, and some msd 5m wires so i can shorten them for the rear dizzy cap.
im going to do it right. not gonna bother half assing it. thats why the 7m car isnt done either. im tired of just getting it done with what i have just to redo it later cause im not happy with it. just gonna do it right the first time and be done.
Well mostly i was curious because of my own plans. and I am looking for a set of webers. Ill be dealing with ignition in another fashion. Ill get with you shortly to see whats going on with the carbs.
Thanks William.
Discussion Starter · #118 ·
no problem. lmk. i need larger then what i have, and these 40's are a mtached set, freshly rebuilt and never used since rebuilt. even have all 6 of the velocity stacks
William, what were you looking for in terms of price for these? My cousin has a 240Z that these might work on.
Discussion Starter · #120 ·
id like $700 plus shipping for the set. but not apposed to real offers. these were on a l28 with cannon intake manifold when i got them. sold the cannon intake years ago.
