I just it a few when I went for a drive. IT WORKS!!!! kewl!!zankone said:dont lock your car from then inside (it triggers the alarm for the next time the door opens), lock it with your keys from the ouside. :wink:
Did you locked it with your key? You know turn the key to lock it!! Try that, if it doesn't work - better fix it like what the expert instructed above!thshiiam said:My alarm goes off even if i lock it from the outside. Everytime I unlock it the alarm goes off. How do I fix that?
You probably need to fix the microswitch on the door lock plate and also the one on the handle. If you want to knock down the annoyingness of the stock alarm disconnect the horn plug for the one on the washer bottle. At least that way you won't hear the horn.My alarm goes off even if i lock it from the outside
