1 - 2 of 2 Posts
What to look out for when buying a MKII
Rust inside rear fenders
YEP
Rust underneath the front spoiler attachment
YEP
Rusty side panels on the doors and rear fenders
YEP
Rusty radiator
DOES GREEN AND CRAPPY COUNT?
Rust on inside seams of doors
YEP HOLES
Rust by rear seatbelts (remove rear seat, leaky sunroof or clogged drain lines)
PROBABLY
Hatch rust (remove hatch trim to see if starting)
YEP
Rust on rear shock towers
NOT YET
Worn automatic windows
HA HA HA HA UNDERSTATEMENT
Faulty heater contact (1st and 2nd settings don’t work)
HAVEN'T TRIED THE HEAT YET
Any, ANY wrong sounds from the differential
MAYBE
Any wrong sounds from the drive shaft
PROBABLY
A/C function
SURPRISINGLY YES
Fog lights (rust)
KINDA
Door hinges
WORK
Sticky valve lifters (5MGE has hydryalyc lifters)
WOULDN'T DOUBT IT PROBABLY REASON FOR ALL THE SMOKE
Worn front wheel bearings
YEP
No jumping out of gear (if a manual)
NAH NOT YET
Digital meter function
EHH
Ignitor
YEP THAT WORKS PUMPED UP THE TIRES W/ IT
Warped rotors (sign of over-torqued lug nuts)
YEP!
Wiper motor (not common but expensive @$300)
THAT ACTUALLY WORKS
1 - 2 of 2 Posts
