WHere is the e-brake on the drivetrain? My ebrake doesn't work and I don't think that it is the brake cable itself seems more like something is broken in the ebrake assembly.
check the cable at the handle. you'll have to remove the console to check it.suprathepeg said:WHere is the e-brake on the drivetrain? My ebrake doesn't work and I don't think that it is the brake cable itself seems more like something is broken in the ebrake assembly.
hrm, just did this 2 days ago, one cable on my 85.CJSREDPRA said:Uhmm.... Correction....
TWO cables from the e-brake lever to the equalizer.... There is a upper & lower cable.
Take it from someone who has had to replace this cable. Add in the fact that you have to snake it around the driveshaft upon install... It is a PITA. And I personally ordered it from Toyota, so I do know it has 2 cables, according to the EPC. :shock:
Nope, just the cost of parts, just make sure you give yourself adaquete(sp?) time to do so.suprathepeg said:If I do the work myself will it be expensive?
Did it before I went to MIR for the meet. One cable on my '86.Dragonfyre said:hrm, just did this 2 days ago, one cable on my 85.CJSREDPRA said:Uhmm.... Correction....
