1 - 8 of 8 Posts
Alright guys so before I start, yes I’m an idiot so don’t worry about calling me one but I need help, I had my alternator go out and on a mostly stock mk2, and replaced it today, now that I’ve replaced it there’s no electricity to the car and I found another wire that’s not connected that I can’t finds home that runs from the same area,I do have pictures
15032
That’s the oil pressure sender wire. The alternator only has one main lead and one plug.
Sent from my iPad using Tapatalk
My first thought is to check the fusible links over at the battery terminal.
Reactions: ddd228
Discussion Starter #4
Alright cool I’m gonna see if I can figure out reconnecting it then, any more info you can give cause I can’t find where it goes and it only has about a foot past the alternator
The sensor is a silver color sensor on the side of the block. It’s about 6 inches back from oil filter.
That is it to the left of the filter. I was thinking of getting this 6m but to far and too much.
Sent from my iPhone using Tapatalk
1 - 8 of 8 Posts
