Hey guys, I have an 88 7mge that I did a gte swap in. Over the course of the last 10 years I've been working on this car. Long story short I can't get it to run. I replaced the engine wiring harness and had the ecm sent out and tested which tested good. Fast forward everything is in the car and most sensors are hooked up minus a coolant temp sensor and a couple others. I'm not getting spark fuel level or even power to the pump. I've checked power to the batt pin on the ecu and have 12v, with the ignition on I have power on every part of the ignition switch except st1 and st2 but I do not have power at the ign sw pin on the ecu. If I jumper the ecu at ignition sw I have spark and main efi relay power but still no fuel pump or anything. I'm at a loss chasing wires with no resolve.
