Back again. 82 P type. Manual Trans.
Tried firing the vehicle up after head gasket replacement and have no spark from the coil/ignitor.
I initially put the distributor in by eyeballing cyl 1 while vehicle timing marks were set to TDC. I now see there is a procedure involving lining up a screw and mark on the distributor, I'll try that this evening when I get home from work, but would that cause me to have no spark at all from the coil?
I checked that I have good output from a test light on the brown 12v wire to the ignitor (left my DMM at work, but bright light tells me good voltage/current flow), and it looks like the ground wire off the ignitor is grounded by the PCM, running through the interior fuse box by driver's kick panel. I didn't diagnose anything in there because I haven't touched any of that.
Grounds I touched look like Engine to firewall, Battery to body, Injector harness to manifold, and one that's by the fuse panel (white and black wire) that goes to body. That ground's bolt broke off when I was trying to clean things up so I relocated it to clean metal and it tests as a good ground.
Only other thing I touched was the MAIN 1 relay. Removed that while cranking to get oil flowing around before I tried my initial start. I do notice with key on, engine off that both the MAIN and EFI relays get pretty hot. Might be normal, just an observation.
I doubt it's the ignitor or coil, car ran just fine (minus bad head gasket) a few months ago. It's got to be something electrical, or if the distributor being off can somehow cause a no spark. I would think it would spark, just out of time if I screwed the dizzy timing up.
Thanks again guys.
Thanks again guys.
