1 - 3 of 3 Posts
Anyone point me in the direction of a pinout on this ECU? It's a RHD NA 2J Non VVTI.
I'm seeing 89661-3A170 but I'm not getting any solid confirmations on what car this is from. Every ECU pinout I see has completely different plugs.
Discussion Starter #3
Ya, I couldn't find a pinout for that car. I ended up using the 1JZ for the body ECU plug(plug T in the attached diagram) and just had to give switched power from the 5M Injector Resistor to power the 2JZ-GE ignition coil/injectors.
1 - 3 of 3 Posts
