1 - 3 of 3 Posts
What is the OEM LSD? I know it’s a clutch type but is it like a 1.5 way or 2 way? Is it good for drifting? Any information helps, thanks!
2-way - can be rebuilt to have more or less lockup torque by using additional clutch plates via Weir'd MAXGRIP kit seen here: Weir Performance - MAXGRIP LSD Kits
As for if it's "good for drifting" - I'm guessing that if you have to ask, then it really won't be the limiting factor for your drifting performance regardless.
--billyM
Its a horrible car for drifting, sell it to someone who cares about it and get an s13 :p
Seriously though, the stock clutch plates won't last long if you drift it, and the rear suspension design is horrible for camber wear and it will eat tires after you lower it even a little.
1 - 3 of 3 Posts
