I have a an 86 MKII with the original OEM stero/Cass/EQ. There was no sound comming from the front speakers. Tested the speakers on a known source, so I assumed it was the receiver. Purchased another OEM stereo from Ebay. Intalled and worked fine (all speakers) until recently. The front right speaker works intermittently. It has sound, I go over a bump then no sound, and back again. I checked the connections and they are clean. It's not the speaker, wire, or harness.
I want to keep the car as OEM as possible. The OEM stereo sound suits me fine. But if the sound from the speaker continues, on/off. I may need to go aftermarket stereo. I could cut off the speaker altogether but the sound is like having one of my ears is clogged.
Is it the stereo? Does the OEM stero loose its abilty to supply sound to the front speakers over time? Is this common for the OEM stereo? What do you guys/gals think?
Thanks
Al
Thanks
Al
