hi. i am currently looking to build a mk2 celica supra for use as an off-road (rally type) vehicle. I was wondering if anyone can suggest a good set of struts that can handle bumps without losing too much traction (and that don't cost an arm and a leg). as far as springs are concerned, i was considering contacting Ground Control to see if i can custom order a set of springs that leave the car at just about stock height (perhaps slightly higher), but have a stiffer rate. Can anyone suggest a good spring rate to get for off road use? i am not too familiar with the weight balance of the mk2, so i was wondering how the f/r spring rates should compare to each other. also, can anyone suggest a good tire for off-road use? i am currently doing my own research on tires, but any suggestions you can give will certainly help. i am considering most likely using a 15x8" wheel all around. does anyone know of any strong cheap wheels that will fit the celica supra? i was looking at Summit Racing at those black steel wheels, but most of them use a 5 lug bolt pattern. they are a great price however. is there any 5-lug swaps available for the mk2? well...sorry for the long first post, but hopefully you guys can be able to help me out, or perhaps point me in the direction of someone who will be able to help. thanks in advance.
